[mapserver-users] Converting PDF files to GeoTiff
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Fri Mar 21 08:08:46 PDT 2014
Hi Mike,
I have GM 15. If you send me a couple of your .PDFs I could benchmark
converting them with GM. GM is good at tiling, if you want the output
broken up, or put in a pyramid.
James
-----Original Message-----
Sent: Friday, March 21, 2014 9:06 AM
To: mapserver-users at lists.osgeo.org
Cc: EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE; jukka.rahkonen at mmmtike.fi
Subject: Converting PDF files to GeoTiff
On a perhaps related subject, I was wondering if there was a preferred way
to convert PDF map files to georeferenced GeoTiffs? I have thousands (many
thousands) of these to convert.
The tools I would like to use in order of preference are:
Perl
QGIS
Any open source software
Global Mapper
I am on Win7.
Here is an example of a file I want to convert:
http://www.mflan.com/temp/ny_west point_140214_1941_62500_geo.pdf
I am also not adverse to downloading the entire country (USA) of GeoTiff 15
minute topos if they exist somewhere, but I have not found a location that
serves them up for free.
Mike
Houston, TX
On 3/21/2014 8:53 AM, mapserver-users-request at lists.osgeo.org wrote:
> Date: Fri, 21 Mar 2014 12:21:30 +0000
> From: "EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE"
> <james.evans.4 at us.af.mil>
> To: "Rahkonen Jukka (Tike)"<jukka.rahkonen at mmmtike.fi>,
> "'mapserver-users at lists.osgeo.org'"
> <mapserver-users at lists.osgeo.org>
> Subject: Re: [mapserver-users] Processing JP2000 files
> Message-ID:
> <20EA793B1BC710448656BDC9BD25C4A104C5B771 at 52ZHTX-D07-04D.area52.afnoap
> ps.usaf.mil>
> Content-Type: text/plain; charset="us-ascii"
> Hi Jukka,
> I have Global Mapper, and used it to do a batch convert to geotiff on a
test set of images. The converted files work fine with the OpenJPEG drive,
but the size almost doubles and on my 10 year old pc at home it takes about
3 minutes per file to convert. I will look at all the options you mentioned
below.
> Thanks!
> James
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140321/698ea49c/attachment.bin>
