[mapserver-users] [MS-master] SLD request and style + label behaviour
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Sat May 3 04:28:22 PDT 2014
First thing to check is if OSM buildings really have names in the data or maybe test by using osm_id as labelitem because it for sure exists for all the buildings. Other things to do is to add also DEBUG 5 into your layer, check that ms_errorfile is set and see what messages it collects. Hmm, and check if font "sc" can be found. Jeff will soon tell you to use shp2img for testing but perhaps a good WMS client is here better because of all the scale dependent layers used in OSM mapfiles.
-Jukka Rahkonen-
Yves Jacolin wrote:
> Hello,
> I am testing MapServer master this week and I found some curious behaviour.
# I am using :
* basemaps for the mapfile with data from OSM in France.
* MapServer master, built today
$ /usr/lib/cgi-bin/mapserv -v
MapServer version 6.5-dev OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=XMP
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
# Testing:
* export sld with GetStyles request on buildings15 layer.
Layer definition:
LAYER
STATUS ON
PROJECTION
"init=epsg:3857"
END
GROUP "default"
NAME "buildings15"
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=france user=yves password=yves
port=5432"
DATA "geometry from (select geometry,osm_id, name as name from
osm_buildings) as foo using unique osm_id using srid=3857"
LABELITEM "name"
PROCESSING "LABEL_NO_CLIP=ON"
PROCESSING "CLOSE_CONNECTION=DEFER"
MAXSCALEDENOM 20313
MINSCALEDENOM 10156
CLASS
STYLE
COLOR "#bbbbbb"
OPACITY 50
END
STYLE
OUTLINECOLOR "#333333"
WIDTH 0
END
LABEL
TYPE TRUETYPE
FONT sc
PARTIALS FALSE
MINFEATURESIZE AUTO
SIZE 8
COLOR 0 0 0
OUTLINECOLOR 255 255 255
OUTLINEWIDTH 2
WRAP ' '
MAXLENGTH 6
ALIGN CENTER
END
END
END
# Issues:
* GetStyle request:
- Gives me a label definition (which seems corrects to me, except that there is
no outlinecolor/width parameters)
- Gives me a stroke-width value of 1 instead of 0
* GetMap request doesn't show any labels
Sorry if this mails comes with differents issues, we can split it on several
different thread if needed.
Regards,
Y.
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com<mailto:yves.jacolin at camptocamp.com>
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140503/e36dc2a0/attachment-0001.html>
