[mapserver-users] ovr and mapserver
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 7 12:25:57 PDT 2014
On 5/7/2014 3:15 PM, Aneta Jadwiga Florczyk wrote:
> Dear list,
> Is it possible to publish a layer that uses overviews?
What do you mean by "overviews"?
Do you want a reference map like a small zoomed out version of your map?
This can be done with OpenLayers or in Mapserver using:
http://mapserver.org/mapfile/reference.html
If you are referring to raster image overviews, Then yes maperver will
read these of you already have them defined. look at gdaladdo for a
command that will create overviews in your rasters. You do not have to
do anything special in mapserver to use them.
-Steve W
