[mapserver-users] How support new epsg db 8.4 with its new codes
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed May 7 13:31:20 PDT 2014
Hi Andrea,
I believe I saw you on another mailing list regarding this, and I think
it should be you to nudge/push/remind the developers to update to EPSG
v8.4 - have you filed a ticket on the GDAL Trac for this upgrade?  (note
that often emails to mailing lists are forgotten by development teams,
but issue trackers are always used for releases)  That way your request
gets ported likely to other projects that use EPSG (such as PROJ.4).
https://trac.osgeo.org/gdal/
Thanks! :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2014-05-07, 9:48 AM, Andrea Peri wrote:
> Hi,
> few time ago in Italy was officialy released the new Reference System
> form our central service (IGM).
> Also in the 1 May 2014 (few day ago) the EPSG organization has released
> the new db (v. 8.4) that support the new Italian Reference Systems with
> its new codes.
> the new codes go from
> epsg::6704 to epsg::6711
> So now start the question to update all the infrastructures to support
> these new codes.
> I'm evaluating the step to have a mapserver that will support this new
> epsg codes.
> My mapserver is working with GDAL/OGR and Spatialite, so my study is
> mainly on these three components.
> I'm just now study-ing how to update the GDAL/OGR to support this new codes.
> But I don't understand if this is mandatory and sufficient to have a
> mapserver that support the new codes.
> Or instead will need some change also in mapserver code.
> thx
More information about the MapServer-users mailing list
