[mapserver-users] MapCache DB Backend
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Mon May 19 01:50:46 PDT 2014
There's already support for BerkleyDB and TokyoCabinet as fast no-SQL backends. I've never seen some benchmarks and TokyoCabinet is currently not enabled in CMake build system. LevelDB hasn't support for concurrent processes. So it can only be used with worker and probably event MPM. I've already started implementing it but currently it has some problems. I'll will try to fix this in the next days and post back when there's a usable version.
Von: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org]" im Auftrag von "TDS [tds at tds-net.de]
Gesendet: Mittwoch, 14. Mai 2014 13:59
An: List (MapServer Users)
Betreff: [mapserver-users] MapCache DB Backend
Hello,
is it possible that someone can implement LevelDB or similar into MapCache?
http://highscalability.com/blog/2012/11/29/performance-data-for-leveldb-berkley-db-and-bangdb-for-rando.html
MfG M. Martin
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
