[mapserver-users] MSSQL connection OGR with mapscript
blackcat18
m18blackcat at hotmail.fr
Fri May 23 02:56:32 PDT 2014
Hi every one,
I am trying to get data from database using mapscript. whithout
layer1.status, my output bitmap is blank with a size of 2000*2000.
When I add layer1.status = 1, I get that error :
/An exception of type 'System.ApplicationException' occurred in
mapscript_csharp.dll but was not handled in user code
Additional information: msDrawMap(): Image handling error. Failed to draw
layer named 'GRADIN3'.;msOGRFileOpen(): OGR error. Open failed for OGR
connection in layer `GRADIN3'.
Unable to initialize connection to the server for
MSSQL:server=192.168.***.***//SQLSERVER2008;database=OPF_GEO;uid=***;pwd=***;tables=SFP_Siege_CAD(geom),
[Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not exist or
access denied./
I am connected to to my database with SQL Server Management so the
connection is ok. May be the connection string is not written correctly. How
can I correct it ?
this is my code:
/ OSGeo.MapServer.mapObj map = new
OSGeo.MapServer.mapObj("C://Users//Sweet live//SkyDrive//Projet
OPENFIELD//MapServer//Programme//WebForm_Map//mapTest.map");
map.setExtent(18118500, 3877472, 18138000, 3892012);
map.setSize(2000, 2000);
// Ge the first layer and set a classification attribute
OSGeo.MapServer.layerObj layer1 = new
OSGeo.MapServer.layerObj(map);
layer1.name = "GRADIN3";
layer1.type = OSGeo.MapServer.MS_LAYER_TYPE.MS_LAYER_POLYGON;
//layer1.status = 1;
//layer1.debug = 1;
layer1.connectiontype =
OSGeo.MapServer.MS_CONNECTION_TYPE.MS_OGR;
layer1.connection =
"MSSQL:server=192.168.***.***//SQLSERVER2008;database=OPF_GEO;uid=***;pwd=***;tables=SFP_Siege_CAD(geom)";
//layer1.data = "select geom from SFP_Siege_CAD";
OSGeo.MapServer.classObj classSiege = new
OSGeo.MapServer.classObj(layer1);
classSiege.name ="geom";
OSGeo.MapServer.styleObj styleSiege = new
OSGeo.MapServer.styleObj(classSiege);
styleSiege.color.setRGB(125,125,125);
classSiege.insertStyle(styleSiege,0);
// map.save("output.map");
OSGeo.MapServer.imageObj mapimage = map.draw();
mapimage.save("map.png", map);/
and the output .map:
/MAP
EXTENT 18118500 3874992 18138000 3894492
FONTSET "fonts\fonts.list"
IMAGETYPE "png"
NAME "MS"
SIZE 2000 2000
STATUS ON
UNITS METERS
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
END # OUTPUTFORMAT
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
STATUS OFF
END # LEGEND
QUERYMAP
SIZE -1 -1
STATUS OFF
STYLE HILITE
END # QUERYMAP
SCALEBAR
IMAGECOLOR 255 255 255
INTERVALS 4
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
SIZE 200 3
STATUS OFF
UNITS MILES
END # SCALEBAR
WEB
END # WEB
LAYER
CONNECTION
"MSSQL:server=192.168.***.***\SQLSERVER2008;database=OPF_GEO;uid=***;pwd=***;tables=SFP_Siege_CAD(geom)"
CONNECTIONTYPE OGR
DEBUG ON
NAME "GRADIN3"
STATUS ON
TILEITEM "location"
TYPE POLYGON
UNITS METERS
CLASS
NAME "geom"
STYLE
ANGLE 0
COLOR 125 125 125
OFFSET 0 0
END # STYLE
STYLE
ANGLE 0
COLOR 125 125 125
OFFSET 0 0
END # STYLE
END # CLASS
END # LAYER
END # MAP/
View this message in context: http://osgeo-org.1560.x6.nabble.com/MSSQL-connection-OGR-with-mapscript-tp5142084.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
