[mapserver-users] post to be accepted
Eichner, Andreas - SID Andreas.Eichner at sid.sachsen.de
Sun May 25 00:44:49 PDT 2014
Have you set MODE=ITEMNQUERY? To me it seems you haven't and MapServer tries to use QSTRING for runtime substitution which it isn't configured for.
HTH
Von: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org]" im Auftrag von "mathias cunault [mathias.cunault at inrap.fr]
Gesendet: Samstag, 24. Mai 2014 17:38
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users] post to be accepted
hello,
(beginner with mapserver 6.4.2)
Despite researchs on the forum, i did not find answers to my question.
I cant perform an itemquery.
I read that a validation block has to be created in LAYER (mapfile), it looks like :
VALIDATION
                "numope" "[a-z]+"
END
I set qlayer, qitem and querystring in template and, but i get :
 mapserv(): Web application error. Parameter 'qstring' value fails to validate. msValidateParameter(): Regular expression error. Parameter pattern validation failed.
it means that my regular exp is wrong or that at least 1 value in the field numope doesn't fit this exp ?
thx
And the attribute in validation has to appear in a classe of the layer or not ?
Thx
Mathias Cunault
chargé d’opération et de recherche
Inrap Tours - 148 av. Maginot
37000 TOURS
06 32 05 98 96
www.inrap.fr
abonnez-vous à la lettre d'information de l'Inrap :
http://www.inrap.fr/newsletter.php
More information about the MapServer-users mailing list
