[mapserver-users] Can a layer (with type UV raster) with a mask have a custom projection?
Jorrit Goddijn
Jorrit.Goddijn at meteogroup.com
Wed May 28 08:32:33 PDT 2014
Hi all,
I have a layer which draws fine with data over the whole world. It has this projection object:
PROJECTION
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs +pm=-360"
END
METADATA
"wms_title" "the current arrow grid"
"wms_srs" "epsg:4326 epsg:54004"
END
If I try to put a MASK on this layer, I get a "NO DATA RECEIVED" error.
The MASK layer draws fine on it's own. I have tried masking this layer with a layer with the same custom projection, but the same result.
This is my layer object:
LAYER
NAME "current_grid"
TYPE POINT
CONNECTIONTYPE uvraster
STATUS OFF
MASK "water_outline" #breaks!
DATA "/var/www/mapserver/data/grib/routeguard/4nwcur99_2013110412.grb2" #v and u-component of current
#PROCESSING "BANDS=1,2"
PROCESSING "UV_SPACING=20"
CLASS
STYLE
SYMBOL "arrow"
ANGLE [uv_angle]
SIZE 10 #we can also use [uv_length] here but this doesnt scale nicely for current. for the file 4nwwin99... it does work as expected.
COLOR 0 255 0
END # style
END # class
PROJECTION
END
METADATA
END
END # layer
Thank you all,
Jorrit
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140528/fddd6f02/attachment-0001.html>
