[mapserver-users] Σχετ: Σχετ: Installation of Mapserver 6.4.1
samuelmesa at gmail.com
Mon Nov 10 13:44:46 PST 2014
Then try the next installation:
sudo apt-get install cgi-mapserver mapserver-bin
Generally, the installation is in /usr. So, the CGI Mapserver is in /usr/lib
/cgi-bin/mapserv.
2014-11-10 15:40 GMT-05:00 Stefanos Anastasiou <emperor_stef at yahoo.gr>:
> Indeed Mint's repositiories are based on Ubuntu's. I just tried the method
> you proposed by adding UbuntuGIS. I get the following:
> Couldn't find package "mapserver". However, the following
> packages contain "mapserver" in their name:
> mapserver-doc cgi-mapserver qgis-mapserver mapserver-bin
> libmapserver1-dev libmapserver1
> No packages will be installed, upgraded, or removed.
> 0 packages upgraded, 0 newly installed, 0 to remove and 87 not upgraded.
> Need to get 0 B of archives. After unpacking 0 B will be used.
> From what I've seen the same packages are on the repositories of Mint 17.
> Should I install what it proposes above? In which folder will it be
> installed..? I was trying to compile it because I though it's necessary to
> be installed in /usr/local/src
> Stefanos
> Στις 9:51 μ.μ. Δευτέρα, 10 Νοεμβρίου 2014, ο/η Samuel Mesa <
> samuelmesa at gmail.com> έγραψε:
> I understand that the Ubuntu repositories are compatible with Linux Mint.
> Have you tried the following solution to install MapServer binaries from
> UbuntuGIS?:
> http://gis.stackexchange.com/questions/72588/how-to-install-qgis-2-0-on-mint-15?answertab=active#tab-top
> For Mapserver:
> sudo aptitude install python-software-properties
> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> sudo aptitude update
> sudo aptitude install mapserver
> El lun, 10 de nov 2014 a las 2:40 PM, Stefanos Anastasiou <
> emperor_stef at yahoo.gr> escribió:
> Hi Samuel,
> I'm using Linux Mint 17. Indeed I installed all libraries through the
> repos and I presume it took care of the dependencies. And that was my
> initial qusestion actually: if i should use the synaptic or compile it from
> scratch. Probably the problem is in the paths of the libraries that cmake
> can't find them but I think the paths are the default paths that the
> synaptic installed them.
> Stefanos
> Στις 9:34 μ.μ. Δευτέρα, 10 Νοεμβρίου 2014, ο/η Samuel Mesa <
> What distribution of Linux you are using Stefanos?. I think you could use
> a package manager to install dependencies and Mapserver.
> El lun, 10 de nov 2014 a las 1:04 PM, Stefanos Anastasiou <
> Hello Samuel..!!!
> No I'm getting the following error:
> CMake Error at CMakeLists.txt:49 (message):
> GEOS library/component/dependency could not be found.
> -- Could NOT find SVG (missing: SVG_LIBRARY SVG_INCLUDE_DIR)
> -- Could NOT find SVGCAIRO (missing: SVGCAIRO_LIBRARY
> SVGCAIRO_INCLUDE_DIR)
> SVGCAIRO library/component/dependency could not be found.
> Could NOT find GDAL (missing: GDAL_LIBRARY GDAL_INCLUDE_DIR)
> CMake Error at CMakeLists.txt:567 (message):
> GDAL library could not be found and is needed for OGR support.
> Found CURL: /usr/lib/i386-linux-gnu/libcurl.so (found version "7.35.0")
> CMake Error at CMakeLists.txt:60 (message):
> CLIENT_WMS support requires GDAL support, however GDAL support has been
> disabled.
> CLIENT_WFS support requires OGR support, however OGR support has been
> disabled.
> WFS support requires OGR support, however OGR support has been disabled.
> KML support requires LIBXML2 support, however LIBXML2 support has been
> disabled.
> SOS support requires LIBXML2 support, however LIBXML2 support has been
> disabled.
> GIF library/component/dependency could not be found.
> CMake Error at
> /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:108
> (message):
> Could NOT find SWIG (missing: SWIG_EXECUTABLE SWIG_DIR)
> Does is have to do with the compiling of the libraries? I installed all
> libraries and their .dev through the repositories. Does it have to do
> anything?
> Thanks a lot.
> Stefanos
> Στις 10:10 μ.μ. Σάββατο, 8 Νοεμβρίου 2014, ο/η "samuelmesa at gmail.com" <
> Try again decompressing the src and ignore step 2:
> 2. rm CMakeCache.txt CMakeFiles
> regards,
> Samuel Mesa.
> 2014-11-08 14:31 GMT-05:00 Stefanos Anastasiou <emperor_stef at yahoo.gr>:
> Hi Samuel,
> Thank you for the reply..!!! I'm getting the following error : CMake
> Error: The source directory "/usr/local/src/mapserver-6.4.1/build" does not
> appear to contain CMakeLists.txt.
> Specify --help for usage, or press the help button on the CMake GUI.
> If I use CMake GUI I get permission error. I've placed the folder in
> /usr/local/src. What should I do ?
> Stefanos
> Στις 3:12 π.μ. Πέμπτη, 6 Νοεμβρίου 2014, ο/η "samuelmesa at gmail.com" <
> Hi Stefanos, the next is the instructions for compiling Mapserver in Arch
> Linux [1]:
> 1. cd to src mapserver
> 3. mkdir build
> 4. cd build
> 5. compiling as:
> cmake .. -DCMAKE_INSTALL_PREFIX=/usr -DPYTHON_EXECUTABLE=/usr/bin/python2 \
> -DPYTHON_LIBRARIES=/usr/lib/python2.7 \
> -DPYTHON_INCLUDE_PATH=/usr/include/python2.7 \
> -DFRIBIDI_INCLUDE_DIR="/usr/include/glib-2.0;/usr/lib/glib-2.0/include;/usr/include/fribidi" \
> -DWITH_CAIRO=ON \
> -DWITH_CLIENT_WFS=ON \
> -DWITH_CLIENT_WMS=ON \
> -DWITH_CSHARP=OFF \
> -DWITH_CURL=ON \
> -DWITH_EXEMPI=OFF \
> -DWITH_FCGI=ON \
> -DWITH_FRIBIDI=ON \
> -DWITH_GD=OFF \
> -DWITH_GDAL=ON \
> -DWITH_GENERIC_NINT=OFF \
> -DWITH_GEOS=ON \
> -DWITH_GIF=ON \
> -DWITH_ICONV=ON \
> -DWITH_JAVA=OFF \
> -DWITH_KML=ON \
> -DWITH_LIBXML2=ON \
> -DWITH_MSSQL2008=OFF \
> -DWITH_MYSQL=OFF \
> -DWITH_OGR=ON \
> -DWITH_ORACLESPATIAL=OFF \
> -DWITH_ORACLE_PLUGIN=OFF \
> -DWITH_PERL=OFF \
> -DWITH_PHP=ON \
> -DWITH_POINT_Z_M=OFF \
> -DWITH_POSTGIS=ON \
> -DWITH_PROJ=ON \
> -DWITH_PYTHON=ON \
> -DWITH_RSVG=OFF \
> -DWITH_RUBY=OFF \
> -DWITH_SDE=OFF \
> -DWITH_SDE_PLUGIN=OFF \
> -DWITH_SOS=ON \
> -DWITH_SVGCAIRO=ON \
> -DWITH_THREAD_SAFETY=ON \
> -DWITH_WCS=ON \
> -DWITH_WFS=ON \
> -DWITH_WMS=ON \
> -DWITH_XMLMAPFILE=OFF \
> -DFREETYPE_INCLUDE_DIR=/usr/include/freetype2 \
> 6. make clean && make
> 7. make install
> regards,
> Samuel Mesa.
> [1] https://aur.archlinux.org/packages/ma/mapserver/PKGBUILD
> 2014-11-04 17:44 GMT-05:00 Stefanos Anastasiou <emperor_stef at yahoo.gr>:
> Hello.!!
> I'm wondering if the installation should be made only with cmake. Can't
> someone just use the repos ? I'm trying to use cmake but getting a lot or
> errors, probably having to do with the PREFIX path. So I'm feeling pretty
> confused. I'm also not that good with linux file system hierarchy.
> Thanks
> Stefanos
> mapserver-users at lists.osgeo.org
> / v \
> / v \
/ v \
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141110/e92571b7/attachment.html>
