[mapserver-users] [mapserver-dev] Configuring TinyOWS with a standard Mapfile in OSGeo4W
samuelmesa at gmail.com
Tue Nov 11 17:56:48 PST 2014
Thanks Jukka for your reply. I published the WFS service configured the
config.xml file in TinyOWS. When I perform the GetCapabilities request, I
have verified that is supported transactional operations:
http://127.0.0.1/cgi-bin/tinyows.exe?Service=WFS&Request=GetCapabilities
<Operations>
<Operation>Query</Operation>
<Operation>Insert</Operation>
<Operation>Update</Operation>
<Operation>Delete</Operation>
</Operations>
In this case, only edits TinyOWS when I add the check_schema="0" attribute
in config.xml, according to [1].
However, when I setup TinyOWS in Mapfile file, this is not possible to
enable transactional operations.
http://localhost/cgi-bin/mapserv.exe?map=C:/OSGeo4W/httpd.d/Mapfile/bogota.map&Service=WFS&Request=GetCapabilities
<Operations>
</Operations>
I have set the environment variable in httpd.conf of Apacha, according to
[2]:
SetEnv TINYOWS_MAPFILE "C:\OSGeo4W/httpd.d/Mapfile/bogota.map"
The software used is OSGeo4W x86, Mapserver 6.4.1, postgis 2.1, TinyOWS
1.1.0 and QGIS 2.4, 2.6 and 2.7 for editing.
I attached the project with all files postgis layers, the mapfile project
and configuration TinyOWS file.
Thanks for your reply.
[1]
http://lists.osgeo.org/pipermail/mapserver-users/2014-January/075869.html
[2] http://mapserver.org/tinyows/mapfileconfig.html
2014-11-11 17:43 GMT-05:00 Rahkonen Jukka (Tike) <jukka.rahkonen at mmmtike.fi>
> Hi,
> Please send your LAYER. Just to make sure that there are no typos etc.
> Check also that user you use for making a connection have
> INSERT/UPDATE/DELETE rights.
> How does QGIS behave? Which QGIS version? Can you switch the layer to
> edit mode? Is just saving the changes that fails?
> -Jukka Rahkonen-
> samuelmesa wrote
> I've tried to create a WFS-T service configuring TinyOWS with a standard
> Mapfile in OSGeo4W, following the instructions in [1].
> The connection is correct but does not enable transccionales operations,
> example using QGIS Desktop.
> Has anyone been able start up the WFS-T service from Mapfile and TinyOWS
> in OSGeo4W? There are limitations on OSGeo4W to publish the WFS-T service
> with Mapfile?
> regards,
> Samuel Mesa.
> [1]. http://mapserver.org/tinyows/mapfileconfig.html
> mapserver-users at lists.osgeo.org
/ v \
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141111/6d8e0546/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141111/6d8e0546/attachment-0001.zip>
