[mapserver-users] MapServer SOS setup questions
Carsen Banister
carsen.banister at gmail.com
Tue Nov 25 08:05:21 PST 2014
Hi Jeff,
Thanks for the reply. Here is my OVF file, which is able to connect to the
database and return information (via Linux command line):
(sostest.ovf):
<OGRVRTDataSource>
<OGRVRTLayer name="Stations">
<SrcDataSource>MYSQL:dbname,user=usr,password=pw,host=127.0.0.1,port=3306,ta
bles=Stations</SrcDataSource>
<SrcSQL>SELECT StationId, Name FROM Stations</SrcSQL>
<Field name="StationName" type="string" src="Name" />
<Field name="StationId" type="string" src="StationId" />
</OGRVRTLayer>
<OGRVRTLayer name="InstrumentReadings">
bles=InstrumentReadings</SrcDataSource>
<SrcSQL>SELECT ReadingValue, ReadingTime FROM InstrumentReadings
WHERE InstrumentId = 134 LIMIT 1000</SrcSQL>
<Field name="Value" type="String" src="ReadingValue"/>
<Field name="Time" type="DateTime" src="ReadingTime"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Here is the map file I would like to link the data to (I've omitted some
metadata entries with ...):
(sostest.map):
MAP
NAME "SOS_server"
STATUS ON
SIZE 300 300
EXTENT -66 44 -62 45
UNITS METERS
SHAPEPATH "./data/"
IMAGECOLOR 255 255 0
IMAGETYPE png
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "OfferingStation_1"
METADATA
"sos_procedure" "OfferingStation_1"
"sos_offering_id" "OfferingStation_1"
"sos_offering_name" "OfferingStation_1"
"sos_observedproperty_id" "Temperature_1 "
"sos_offering_intendedapplication" "Application"
"sos_offering_timeextent" "2013-11-29T00:00:00Z/"
"sos_describesensor_url"
"http://trac.osgeo.org/mapserver/browser/trunk/msautotest/wxs/data/sos-%proc
edure%.xml?format=raw"
END
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "sostest.ovf"
DATA "Stations"
PROJECTION
"init=epsg:4326"
END
END
LAYER
NAME "OfferingStation_2"
METADATA
"sos_procedure" "OfferingStation_2"
"sos_offering_id" "OfferingStation_2"
"sos_offering_name" "OfferingStation_2"
"sos_observedproperty_id" "Temperature_2"
"sos_offering_timeextent" "2013-11-29T00:00:00Z"
END
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
DATA "Stations"
PROJECTION
"init=epsg:4326"
END
END
END #map
Regards,
Carsen
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: November 25, 2014 8:21 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] MapServer SOS setup questions
Hi Carsen,
Regarding .ovf configuration, MySQL connections are well documented, with
examples[1]. Or, if you already have an ovf connection, maybe you should
paste it into your message so that the whole mailing list community can help
you along.
In terms of SOS servers, I am also aware of a very active project named
istSOS, that you should take a look at[2].
[1] http://mapserver.org/input/vector/mysql.html
[2]
https://geoservice.ist.supsi.ch/projects/istsos/index.php/Welcome_to_istSOS_
project
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
On 2014-11-24 9:50 PM, Carsen Banister wrote:
> Hi,
> I would appreciate any help on some items associated with setting up
> MapServer SOS. I am quite new to MapServer, and am trying to get up to
> speed as quickly as possible. The reason for using MapServer's SOS is
> that the database structure is custom and I'm not aware of any other SOS
> servers that support custom MySQL databases (if you can point me in a
> direction easier than MapServer, please do!).
> So, the questions I am hoping to get clarification on are:
> 1.How do you connect different layers together? e.g. layer and sublayer.
> What is the syntax for that in the mapfile?
> 2.Is there a way to dynamically generate layers (e.g. from database
> query result), or does the layer structure have to be hardcoded?
> 3.When you do a GetObservation, how do you set up MapServer so that that
> request pulls data from the database, e.g. OVF file configuration?
> Thanks in advance for any assistance.
> Best regards,
> Carsen
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
