[mapserver-users] Mapfile limit size
Prigent, Glenn
glenn.prigent at capgemini.com
Wed Nov 26 06:06:34 PST 2014
Hello,
i wonder if there is any size limit for the mapfile.
I have a mapfile (23 ko) which includes many other file (17 includes of a 0.517 ko file, 7 includes of a 6.466 ko file, 6 includes of a 5.996 ko file and 4 includes of a 5.788 ko file)
I use url parameters to filter data with %% in the mapfile.
With some parameters i have a ERROR 500 and sometimes i get no response from mapserver (timeout).
I use regexp in mapfile from BBOX url to filter data in request.
With this BBOX : BBOX=0.61720000000017,37.762166666667,1.6673000000002,39.51233, no problem.
With this BBOX : BBOX=0.61720000000017,37.762166666667,1.6673000000002,39.51233333333, timeout
With this BBOX : BBOX=0.61720000000017,37.762166666667,1.6673000000002,39.512333333333, ERROR 500.
I have no log when those errors come.
I guess it was a BBOX touble but testing those BBOX on another mapfile, everything is ok.
After removing some tabulations from an include file, everything works fine.
So i suppose there is a size limit problem.
Has anyone encountered the same problem and has a solution ?
(I will reformat my mapfile by removing tabulations to avoid the problem)
Glenn Prigent
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141126/3f5b3451/attachment-0001.html>
