[mapserver-users] Raster projection troubles - empty image by projection epsg:31255
Rahkonen Jukka (Tike) jukka.rahkonen at mmmtike.fi
Tue Sep 2 07:43:35 PDT 2014
Your system seems to have Northing-Easting axis order http://epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::31255&reportDetail=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=EPSG:31255
Check if your BBOX has north coordinates first. If not, flip the coordinates or alternatively change your WMS version into 1.1.1 and CRS into SRS and keep your BBOX.
-Jukka Rahkonen-
Bartlomiej Burkot wrote:
Hi
I spent much time searching for reason why my raster does not appear in WMS layer.
My raster is in EPSG:31255 projection
gdalinfo samle_raster.tif
Driver: GTiff/GeoTIFF
Files: samle_raster.tif
Size is 5000, 4000
Coordinate System is:
PROJCS["MGI / Austria GK Central",
    GEOGCS["MGI",
        DATUM["Militar_Geographische_Institute",
            SPHEROID["Bessel 1841",6377397.155,299.1528128000008,
                AUTHORITY["EPSG","7004"]],
            TOWGS84[577.326,90.129,463.919,5.137,1.474,5.297,2.4232],
            AUTHORITY["EPSG","6312"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4312"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",13.33333333333333],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",-5000000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","31255"]]
Origin = (-112500.000000057683792,274999.999999893829226)
Pixel Size = (0.249999999999589,-0.249999999999589)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
  TIFFTAG_XRESOLUTION=72
  TIFFTAG_YRESOLUTION=72
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  ( -112500.000,  275000.000) ( 11d50'13.22"E, 47d36'16.17"N)
Lower Left  ( -112500.000,  274000.000) ( 11d50'14.14"E, 47d35'43.80"N)
Upper Right ( -111250.000,  275000.000) ( 11d51'13.05"E, 47d36'16.95"N)
Lower Right ( -111250.000,  274000.000) ( 11d51'13.96"E, 47d35'44.57"N)
Center      ( -111875.000,  274500.000) ( 11d50'43.59"E, 47d36' 0.37"N)
Band 1 Block=5000x1 Type=Byte, ColorInterp=Red
  Description = Band_1
  Metadata:
    LAYER_TYPE=athematic
Band 2 Block=5000x1 Type=Byte, ColorInterp=Green
  Description = Band_2
  Metadata:
Band 3 Block=5000x1 Type=Byte, ColorInterp=Blue
  Description = Band_3
  Metadata:
I can show it in qgis and reproject to any coordinate system for example epsg:3857.
My mapfile is:
MAP
    IMAGETYPE     PNG
    EXTENT          -120000 270000 -110000 275000
    SIZE           800 600
    RESOLUTION 72
    CONFIG "MS_ERRORFILE" "../log/ms_error_standard.log"
    DEBUG 5
    NAME     myname
    CONFIG "CPL_DEBUG" "ON"
    CONFIG "PROJ_DEBUG" "ON"
    CONFIG "PROJ_LIB" "/usr/share/proj/"
    PROJECTION
        "init=epsg:31255"
    END
    WEB
        METADATA
            wms_title "standard data in wgw"
            "wms_enable_request" "GetMap GetFeatureInfo GetCapabilities"
            "wms_srs" "EPSG:31255 EPSG:4326 EPSG:3857 EPSG:2180 EPSG:31287"
        END
    END
    LAYER
        NAME "oneRaster"
        DATA "samle_raster.tif"
        TYPE RASTER
        STATUS ON
        PROJECTION
          "init=epsg:31255"
        END
        METADATA
            wms_title "Sample raster"
            wms_srs "EPSG:31255"
        END
    END
END #MAP
I'm using mapserver 6.4.1 in cgi mode on the Ubuntu 14.04 linux installed with apt-get install cgi-mapserver:
/usr/lib/cgi-bin/mapserv -v
MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
When Im requesting a map:
http://myhost/cgi-bin/wmsstandard?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-112516.67630140134133399,273973.2257158225402236,-111233.66681915351364296,275020.36552757304161787&CRS=EPSG:31255&WIDTH=1038&HEIGHT=846&LAYERS=oneRaster&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96
I got a message in /var/log/apache2/error.log
[Tue Sep 02 15:01:30.386845 2014] [cgi:error] [pid 2057] [client myip:65403] AH01215: GDAL: GDALOpen(/pathto/sample.tif, this=0x819310) succeeds as GTiff.
[Tue Sep 02 15:01:30.396083 2014] [cgi:error] [pid 2057] [client myip:65403] AH01215: GDAL: GDALClose(/pathto/sample.tif,, this=0x819310)
ms_error_standard.log:
[Tue Sep  2 15:04:45 2014].609914 CGI Request 1 on process 5909
[Tue Sep  2 15:04:45 2014].610243 msWMSLoadGetMapParams(): enabling non-square pixels.
[Tue Sep  2 15:04:45 2014].614988 msDrawMap(): kicking into non-square pixel preserving mode.
[Tue Sep  2 15:04:45 2014].615034 msDrawMap(): rendering using outputformat named AGG_JPEG (AGG/JPEG).
[Tue Sep  2 15:04:45 2014].615064 msDrawMap(): WMS/WFS set-up and query, 0.000s
[Tue Sep  2 15:04:45 2014].617587 msDrawRasterLayerLow(oneRaster): entering.
[Tue Sep  2 15:04:45 2014].619764 msDrawMap(): Layer 1 (oneRaster), 0.005s
[Tue Sep  2 15:04:45 2014].619805 msDrawMap(): Drawing Label Cache, 0.000s
[Tue Sep  2 15:04:45 2014].619816 msDrawMap() total time: 0.009s
[Tue Sep  2 15:04:45 2014].627898 msSaveImage(stdout) total time: 0.008s
[Tue Sep  2 15:04:45 2014].628129 mapserv request processing time (msLoadMap not incl.): 0.018s
[Tue Sep  2 15:04:45 2014].628152 msFreeMap(): freeing map at 0xd0c570.
The requested image is white/empty
The proj4 epsg file does include my projection:
more /usr/share/proj/epsg | grep 31255
#<31255> +proj=tmerc +lat_0=0 +lon_0=13.33333333333333 +k=1 +x_0=0 +y_0=-5000000 +datum=hermannskogel +units=m +no_defs  <>
<31255> +proj=tmerc +lat_0=0 +lon_0=13.33333333333333 +k=1 +x_0=0 +y_0=-5000000 +ellps=bessel +towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232 +units=m +no_defs  <>
And pcs.csv as well:
 more /usr/share/gdal/1.10/pcs.csv | grep 31255
31255,"MGI / Austria GK Central",9001,4312,18005,9807,1,0,4530,8801,0,9110,8802,13.2,9110,8805,1,9201,8806,0,9001,8807,-5000000,9001,,,,,,
When I convert the rasterfile to epsg:3857 using gdalwarp and request Layer in the same crs  &CRS=EPSG:31255& I get the correct getMap request. If I switch to &CRS=EPSG:31255& to force mapserver to reproject I got the same white/empty image.
Could somebody help me?
I can send you a sample of raster on email address.
Bartek
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140902/b564795d/attachment.htm>
More information about the MapServer-users mailing list
