[mapserver-users] Debugging mapserver 6.2
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Sep 2 08:21:00 PDT 2014
On 2014-09-02 12:01 PM, Antti J. Lind wrote:
> Hello list,
> I try to debug mapserver (version 6.2.2) without success.
> I have set on map-file
> CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
> DEBUG 5
> and run web-application.
> Log file shows up on /tmp-directory, but it's allways empty.
> ll /tmp/ms_*
> -rw-r--r-- 1 apache apache 0 Sep 2 12:16 /tmp/ms_error.txt
> Ideas?
> Antti J. Lind
You might also use the shp2img commandline utility with the '-all_debug
5' switch.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
