[mapserver-users] Oracle layer partially drawn
Geograma
amanero at geograma.com
Wed Sep 3 01:32:16 PDT 2014
Hello,
With MapServer for Windows (3.0.6 updated to MapServer 6.2.0-beta4), I’m
writing a “.map” that uses data from an Oracle 11g schema. All looks OK but,
when a map is requested, only some features are drawn. In the log there is
no error or warning. Anybody knows what is happening? (any suggestion will
be appreciated)
Attached are two images, one with the map that should be got (data in a
PostGis server), another with the map got from Oracle and the “.map” used to
generate the second image.
<http://osgeo-org.1560.x6.nabble.com/file/n5159828/oracle.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5159828/postgis.png>
Tha ".map" file is as follows:
MAP
NAME TEST
EXTENT -1450047 2763292 2122072 5658922
SYMBOLSET "symbols.sym"
FONTSET "font.list"
LEGEND
IMAGECOLOR -1 -1 -1
LABEL
FONT "vera"
ANGLE FOLLOW
COLOR 0 0 0
ENCODING "UTF-8"
TYPE truetype
SIZE 8
END
STATUS ON
TRANSPARENT ON
END
WEB
METADATA
"wms_encoding" "UTF-8"
"wms_title" "title"
"wms_abstract" ""
"wms_srs" "epsg:23030 epsg:4326"
"wms_enable_request" "*"
"wms_onlineresource"
"http://v-0049:8080/fcgi-bin/mapserv.exe?map=C:\\ms4w\\maps\\test.map"
labelcache_map_edge_buffer "-10"
END
END
PROJECTION
"init=epsg:23030"
END
#CONFIG MS_ERRORFILE "c:\\ms4w_3_0_6\\maps\\logs\\test.log"
#DEBUG 5
IMAGECOLOR 153 179 204
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION QUALITY=100
FORMATOPTION "INTERLACE=OFF"
END
LAYER
NAME "geo_r3_500K-1M"
STATUS ON
TYPE LINE
CONNECTIONTYPE oraclespatial
CONNECTION "user/pass at service"
DATA "geom from geo_r3 using unique id srid 23030"
MAXSCALEDENOM 749210
MINSCALEDENOM 149750
TRANSPARENCY 100
SIZEUNITS pixels
DUMP TRUE
PROJECTION
"init=epsg:23030"
END
CLASS
STYLE
INCLUDE 'defs/roundedline.def'
COLOR 170 170 170
WIDTH 5
END
STYLE
COLOR 255 255 115
WIDTH 2
END
NAME "default"
END
METADATA
"wms_title" "public.geo_r3_500K-1M"
"wms_abstract" "Capa del Servicio WMS"
"wms_extent" "-971136.125 3134652.25 1051167.75 4846924.0"
"gml_include_items" "all"
END
PROCESSING "CLOSE_CONNECTION=DEFER"
END # Layer
END # Map File
View this message in context: http://osgeo-org.1560.x6.nabble.com/Oracle-layer-partially-drawn-tp5159828.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
