[mapserver-users] how to make symbol rotate with the map?
Oliver Christen
oliver.christen at camptocamp.com
Thu Sep 4 01:48:37 PDT 2014
dear all
I need to make a symbol rotate with the map, i.e. if my symbol has an
angle of 45° and the map is rotated by, let say, 10°, the symbol angle
should be 55° to keep it's orientation relative to the map itself.
at the moment the only way I see is to dynamically set in my database
the angle values to be used for the symbol calculated from the angle of
the map selected by the user (which is totally dynamic, not a configured
value), and that's horrendously annoying as I would have to dynamically
set the data value for the given layer so it use the dynamically
generated angles values.
is there any other way to make a symbol angle follow the map rotation ?
thanks for reading
best regards
Oliver
Camptocamp SA
Oliver Christen
PSE A, EPFL
CH-1015 Lausanne
www.camptocamp.com
+41 21 619 10 23 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
