[mapserver-users] Installing MapServer with FastCGI
Francesco Pirotti - UNIPD
francesco.pirotti at unipd.it
Thu Sep 25 08:58:10 PDT 2014
Did you install the fast-cgi *development *files? I think you installed
the apache fcgi module, but not the dependencies so mapserver
compilation is missing the header files.
Something like:
/apt/-/get/install libfcgi-/dev
/should work for installing the required dependencies.
Google a bit for that.
Cheers,
Francesco
*FRANCESCO PIROTTI *
*CIRGEO Interdepartmental Research Center in Geomatics *
*TESAF Department of Land, Environment, Agriculture and Forestry *
Università di Padova
Via dell'Università, 16
35020 -- Legnaro (PD),Italy
Tel: +39 049 827 2710
Cell.: +39 392 395 2067
Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
Skype: francesco197576
Web: http://www.cirgeo.unipd.it/fp
Il 25/09/2014 16:55, jdmorgan ha scritto:
> Hello,
> I am trying to compile a version of MapServer 6.4.1. on CentOS 6.
> I am at the part where I am doing a CMAKE. I have installed FastCGI
> already however (following
> http://linuxwave.blogspot.com/2010/08/installing-apache-modfastcgifastcgi.html).
> However, I am not really sure where it installed which brings me to my
> issue.
> Currently here is the error I get when running the CMAKE:
> /CMake Error at CMakeLists.txt:49 (message):/
> /FCGI library/component/dependency could not be found./
> /HINTS:/
> /- disable FCGI support by adding -DWITH_FCGI=0/
> /- add the FCGI install directory to the CMAKE_PREFIX_PATH variable
> (-DCMAKE_PREFIX_PATH="/path/to/FCGI-install-dir;/path/to/other/dirs"/
> /Call Stack (most recent call first):/
> /CMakeLists.txt:482 (report_optional_not_found)/
> I have tried in my CMAKE script to point to where I think that FCGI
> (FastCGI) is but this doesn't seem to be working for me.Anyone out
> there have success with this type of thing that can point me in the
> right direction?
> Thanks,
> Derek
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140925/7393e0a8/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140925/7393e0a8/attachment-0001.jpg>
