[mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
Marco Afonso
mafonso333 at gmail.com
Fri Apr 10 06:11:00 PDT 2015
Hi Richard and thank you for your reply :)
Ok... from shell I should be able to read ecw file metadata, right?
Im putting here gdalinfo and ogrinfo outputs.
$ gdalinfo --formats
VRT (rw+v): Virtual Raster
GTiff (rw+vs): GeoTIFF
NITF (rw+vs): National Imagery Transmission Format
RPFTOC (rovs): Raster Product Format TOC format
ECRGTOC (rovs): ECRG TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (rov): CEOS SAR Image
CEOS (rov): CEOS Image
JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+v): ELAS
AIG (rov): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
GRASSASCIIGrid (rov): GRASS ASCII Grid
SDTS (rov): SDTS Raster
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (rov): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (rov): Envisat Image Format
BSB (rov): Maptech BSB Nautical Charts
XPM (rwv): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (rov): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ros): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
GMT (rw): GMT NetCDF Grid Format
netCDF (rw+s): Network Common Data Format
HDF4 (ros): Hierarchical Data Format Release 4
HDF4Image (rw+): HDF4 Dataset
ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
PDS (rov): NASA Planetary Data System
TIL (rov): EarthWatch .TIL
ERS (rw+v): ERMapper .ers Labelled
ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
L1B (rovs): NOAA Polar Orbiter Level 1b Data Set
FIT (rwv): FIT Image
GRIB (rov): GRIdded Binary (.grb)
JPEG2000 (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1)
RMF (rw+v): Raster Matrix Format
WCS (rovs): OGC Web Coverage Service
WMS (rwvs): OGC Web Map Service
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+v): Idrisi Raster A.1
INGR (rw+v): Intergraph Raster
GSAG (rwv): Golden Software ASCII Grid (.grd)
GSBG (rw+v): Golden Software Binary Grid (.grd)
GS7BG (rw+v): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (rov): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
MAP (rov): OziExplorer .MAP
PNM (rw+v): Portable Pixmap Format (netpbm)
DOQ1 (rov): USGS DOQ (Old Style)
DOQ2 (rov): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (rov): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (rov): GSC Geogrid
FAST (rov): EOSAT FAST Format
BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
LAN (rw+v): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (rov): NLAPS Data Format
EIR (rov): Erdas Imagine Raw
DIPEx (rov): DIPEx
LCP (rwv): FARSITE v.4 Landscape File (.lcp)
GTX (rw+v): NOAA Vertical Datum .GTX
LOSLAS (rov): NADCON .los/.las Datum Grid Shift
NTv2 (rw+vs): NTv2 Datum Grid Shift
CTable2 (rw+v): CTable2 Datum Grid Shift
ACE2 (rov): ACE2
SNODAS (rov): Snow Data Assimilation System
KRO (rw+v): KOLOR Raw
ARG (rwv): Azavea Raster Grid format
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
HTTP (ro): HTTP Fetching Wrapper
BAG (ro): Bathymetry Attributed Grid
HDF5 (ros): Hierarchical Data Format Release 5
HDF5Image (ro): HDF5 Dataset
NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
ADRG (rw+vs): ARC Digitized Raster Graphics
SRP (rovs): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
Rasterlite (rws): Rasterlite
PostGISRaster (rws): PostGIS Raster driver
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
KMLSUPEROVERLAY (rwv): Kml Super Overlay
XYZ (rwv): ASCII Gridded XYZ
HF2 (rwv): HF2/HFZ heightfield raster
PDF (rw): Geospatial PDF
OZI (rov): OziExplorer Image File
CTG (rov): USGS LULC Composite Theme Grid
E00GRID (rov): Arc/Info Export E00 GRID
ZMap (rwv): ZMap Plus Grid
NGSGEOID (rov): NOAA NGS Geoid Height Grids
MBTiles (rov): MBTiles
IRIS (rov): IRIS data (.PPI, .CAPPi etc)
$ ogrinfo 005991Argb_12_d73.ecw
FAILURE:
Unable to open datasource `005991Argb_12_d73.ecw' with the following
drivers.
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> REC
-> Memory
-> BNA
-> CSV
-> NAS
-> GML
-> GPX
-> KML
-> GeoJSON
-> Interlis 1
-> Interlis 2
-> GMT
-> GPKG
-> SQLite
-> ODBC
-> WAsP
-> PGeo
-> MSSQLSpatial
-> PostgreSQL
-> PCIDSK
-> OpenFileGDB
-> XPlane
-> AVCBin
-> AVCE00
-> DXF
-> Geoconcept
-> GeoRSS
-> GPSTrackMaker
-> VFK
-> PGDump
-> OSM
-> GPSBabel
-> SUA
-> OpenAir
-> PDS
-> WFS
-> HTF
-> AeronavFAA
-> Geomedia
-> EDIGEO
-> GFT
-> GME
-> SVG
-> CouchDB
-> Idrisi
-> ARCGEN
-> SEGUKOOA
-> SEGY
-> ElasticSearch
-> PDF
-> Walk
-> CartoDB
-> SXF
2015-04-10 1:19 GMT+01:00 Richard Greenwood <richard.greenwood at gmail.com>:
> Why are you using a shapefile? Is it a tile index? Have you tried
> accessing the ecw file directly? Something like:
> LAYER
> NAME "ecw"
> STATUS default
> TYPE raster
> DATA "/fullpath/to/0608A1Argb_12_d73.ecw"
> END
> Ubuntu probably installed gdal, so you may have two copied. To see which
> one is first, try
> which -a gdalinfo
> and verify that the version with ecw support is first.
> And if you are still having trouble, please post your layer definition.
> rich
> On Thu, Apr 9, 2015 at 8:54 AM, Marco Afonso <mafonso333 at gmail.com> wrote:
>> Hi all,
>> Installed mapserver with apt-get.
>> I've installed gdal manually: compiled with ecw support (gdalinfo tell me
>> that).
>> I'm trying to use a shapefile (which points to ecw files) on mapserver
>> but comes the error (the relevant part):
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'ortos2012'.
>> msDrawRasterLayerLow(): Unable to access file. Corrupt, empty or missing
>> file '/fullpath/to/0608A1Argb_12_d73.ecw
>> Note also that I'm using the full path to the ecw.
>> Any ideas please? Thanks :)
>> Regards,
>> Marco Afonso
>> http://goo.gl/ZDtQjm
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
Regards,
Marco Afonso
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150410/eadac47a/attachment-0001.html>
