[mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
Marco Afonso
mafonso333 at gmail.com
Fri Apr 10 06:17:24 PDT 2015
Hi Jukka,
Hmm... something bad!
$ gdalinfo 005991Argb_12_d73.ecw
terminate called after throwing an instance of 'std::length_error'
what(): basic_string::_S_create
Aborted (core dumped)
2015-04-10 14:12 GMT+01:00 Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi>:
> Hi,
> Use gdalinfo instead of ogrinfo.
> -Jukka Rahkonen
> Marco Afonso wrote:
> Hi Richard and thank you for your reply :)
> Ok... from shell I should be able to read ecw file metadata, right?
> Im putting here gdalinfo and ogrinfo outputs.
> $ gdalinfo --formats
> VRT (rw+v): Virtual Raster
> GTiff (rw+vs): GeoTIFF
> NITF (rw+vs): National Imagery Transmission Format
> RPFTOC (rovs): Raster Product Format TOC format
> ECRGTOC (rovs): ECRG TOC format
> HFA (rw+v): Erdas Imagine Images (.img)
> SAR_CEOS (rov): CEOS SAR Image
> CEOS (rov): CEOS Image
> JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
> GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
> ELAS (rw+v): ELAS
> AIG (rov): Arc/Info Binary Grid
> AAIGrid (rwv): Arc/Info ASCII Grid
> GRASSASCIIGrid (rov): GRASS ASCII Grid
> SDTS (rov): SDTS Raster
> DTED (rwv): DTED Elevation Raster
> PNG (rwv): Portable Network Graphics
> JPEG (rwv): JPEG JFIF
> MEM (rw+): In Memory Raster
> JDEM (rov): Japanese DEM (.mem)
> GIF (rwv): Graphics Interchange Format (.gif)
> BIGGIF (rov): Graphics Interchange Format (.gif)
> ESAT (rov): Envisat Image Format
> BSB (rov): Maptech BSB Nautical Charts
> XPM (rwv): X11 PixMap Format
> BMP (rw+v): MS Windows Device Independent Bitmap
> DIMAP (rov): SPOT DIMAP
> AirSAR (ro): AirSAR Polarimetric Image
> RS2 (ros): RadarSat 2 XML Product
> PCIDSK (rw+v): PCIDSK Database File
> PCRaster (rw): PCRaster Raster File
> ILWIS (rw+v): ILWIS Raster Map
> SGI (rw+): SGI Image File Format 1.0
> SRTMHGT (rwv): SRTMHGT File Format
> Leveller (rw+): Leveller heightfield
> Terragen (rw+): Terragen heightfield
> GMT (rw): GMT NetCDF Grid Format
> netCDF (rw+s): Network Common Data Format
> HDF4 (ros): Hierarchical Data Format Release 4
> HDF4Image (rw+): HDF4 Dataset
> ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
> ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
> PDS (rov): NASA Planetary Data System
> TIL (rov): EarthWatch .TIL
> ERS (rw+v): ERMapper .ers Labelled
> ECW (rw): ERDAS Compressed Wavelets (SDK 3.x)
> JP2ECW (rw+v): ERDAS JPEG2000 (SDK 3.x)
> L1B (rovs): NOAA Polar Orbiter Level 1b Data Set
> FIT (rwv): FIT Image
> GRIB (rov): GRIdded Binary (.grb)
> JPEG2000 (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1)
> RMF (rw+v): Raster Matrix Format
> WCS (rovs): OGC Web Coverage Service
> WMS (rwvs): OGC Web Map Service
> MSGN (ro): EUMETSAT Archive native (.nat)
> RST (rw+v): Idrisi Raster A.1
> INGR (rw+v): Intergraph Raster
> GSAG (rwv): Golden Software ASCII Grid (.grd)
> GSBG (rw+v): Golden Software Binary Grid (.grd)
> GS7BG (rw+v): Golden Software 7 Binary Grid (.grd)
> COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
> TSX (rov): TerraSAR-X Product
> COASP (ro): DRDC COASP SAR Processor Raster
> R (rwv): R Object Data Store
> MAP (rov): OziExplorer .MAP
> PNM (rw+v): Portable Pixmap Format (netpbm)
> DOQ1 (rov): USGS DOQ (Old Style)
> DOQ2 (rov): USGS DOQ (New Style)
> ENVI (rw+v): ENVI .hdr Labelled
> EHdr (rw+v): ESRI .hdr Labelled
> GenBin (rov): Generic Binary (.hdr Labelled)
> PAux (rw+): PCI .aux Labelled
> MFF (rw+): Vexcel MFF Raster
> MFF2 (rw+): Vexcel MFF2 (HKV) Raster
> FujiBAS (ro): Fuji BAS Scanner Image
> GSC (rov): GSC Geogrid
> FAST (rov): EOSAT FAST Format
> BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
> LAN (rw+v): Erdas .LAN/.GIS
> CPG (ro): Convair PolGASP
> IDA (rw+): Image Data and Analysis
> NDF (rov): NLAPS Data Format
> EIR (rov): Erdas Imagine Raw
> DIPEx (rov): DIPEx
> LCP (rwv): FARSITE v.4 Landscape File (.lcp)
> GTX (rw+v): NOAA Vertical Datum .GTX
> LOSLAS (rov): NADCON .los/.las Datum Grid Shift
> NTv2 (rw+vs): NTv2 Datum Grid Shift
> CTable2 (rw+v): CTable2 Datum Grid Shift
> ACE2 (rov): ACE2
> SNODAS (rov): Snow Data Assimilation System
> KRO (rw+v): KOLOR Raw
> ARG (rwv): Azavea Raster Grid format
> RIK (ro): Swedish Grid RIK (.rik)
> USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
> GXF (ro): GeoSoft Grid Exchange Format
> HTTP (ro): HTTP Fetching Wrapper
> BAG (ro): Bathymetry Attributed Grid
> HDF5 (ros): Hierarchical Data Format Release 5
> HDF5Image (ro): HDF5 Dataset
> NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
> NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
> ADRG (rw+vs): ARC Digitized Raster Graphics
> SRP (rovs): Standard Raster Product (ASRP/USRP)
> BLX (rw): Magellan topo (.blx)
> Rasterlite (rws): Rasterlite
> PostGISRaster (rws): PostGIS Raster driver
> SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
> KMLSUPEROVERLAY (rwv): Kml Super Overlay
> XYZ (rwv): ASCII Gridded XYZ
> HF2 (rwv): HF2/HFZ heightfield raster
> PDF (rw): Geospatial PDF
> OZI (rov): OziExplorer Image File
> CTG (rov): USGS LULC Composite Theme Grid
> E00GRID (rov): Arc/Info Export E00 GRID
> ZMap (rwv): ZMap Plus Grid
> NGSGEOID (rov): NOAA NGS Geoid Height Grids
> MBTiles (rov): MBTiles
> IRIS (rov): IRIS data (.PPI, .CAPPi etc)
> $ ogrinfo 005991Argb_12_d73.ecw
> FAILURE:
> Unable to open datasource `005991Argb_12_d73.ecw' with the following
> drivers.
> -> ESRI Shapefile
> -> MapInfo File
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> S57
> -> DGN
> -> VRT
> -> REC
> -> Memory
> -> BNA
> -> CSV
> -> NAS
> -> GML
> -> GPX
> -> KML
> -> GeoJSON
> -> Interlis 1
> -> Interlis 2
> -> GMT
> -> GPKG
> -> SQLite
> -> ODBC
> -> WAsP
> -> PGeo
> -> MSSQLSpatial
> -> PostgreSQL
> -> PCIDSK
> -> OpenFileGDB
> -> XPlane
> -> AVCBin
> -> AVCE00
> -> DXF
> -> Geoconcept
> -> GeoRSS
> -> GPSTrackMaker
> -> VFK
> -> PGDump
> -> OSM
> -> GPSBabel
> -> SUA
> -> OpenAir
> -> PDS
> -> WFS
> -> HTF
> -> AeronavFAA
> -> Geomedia
> -> EDIGEO
> -> GFT
> -> GME
> -> SVG
> -> CouchDB
> -> Idrisi
> -> ARCGEN
> -> SEGUKOOA
> -> SEGY
> -> ElasticSearch
> -> PDF
> -> Walk
> -> CartoDB
> -> SXF
> 2015-04-10 1:19 GMT+01:00 Richard Greenwood <richard.greenwood at gmail.com>:
> Why are you using a shapefile? Is it a tile index? Have you tried
> accessing the ecw file directly? Something like:
> LAYER
> NAME "ecw"
> STATUS default
> TYPE raster
> DATA "/fullpath/to/0608A1Argb_12_d73.ecw"
> END
> Ubuntu probably installed gdal, so you may have two copied. To see which
> one is first, try
> which -a gdalinfo
> and verify that the version with ecw support is first.
> And if you are still having trouble, please post your layer definition.
> rich
> On Thu, Apr 9, 2015 at 8:54 AM, Marco Afonso <mafonso333 at gmail.com> wrote:
> Hi all,
> Installed mapserver with apt-get.
> I've installed gdal manually: compiled with ecw support (gdalinfo tell me
> that).
> I'm trying to use a shapefile (which points to ecw files) on mapserver but
> comes the error (the relevant part):
> msDrawMap(): Image handling error. Failed to draw layer named
> 'ortos2012'.
> msDrawRasterLayerLow(): Unable to access file. Corrupt, empty or missing
> file '/fullpath/to/0608A1Argb_12_d73.ecw
> Note also that I'm using the full path to the ecw.
> Any ideas please? Thanks :)
> Regards,
> Marco Afonso
> http://goo.gl/ZDtQjm
> mapserver-users at lists.osgeo.org
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
> Regards,
> Marco Afonso
Regards,
Marco Afonso
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150410/291245bf/attachment.html>
