[mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
Marco Afonso
mafonso333 at gmail.com
Sat Apr 11 03:57:09 PDT 2015
Hi Jukka,
We have exactly the same MS configuration, shapefile and ECW files working
a older windows machine, so it seems to me that it is something to do with
ms on linux.
As I stated before, gdalinfo and ogrinfo are reading corretly the shapefile
and ecw files throught command line.
What file permitions would be required?
Thanks
2015-04-11 11:21 GMT+01:00 Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi>:
> Hi,
> About how to test I have only one advice: Do it systematically.
> Being systematically means building something pretty simple that works
> first and add new stuff one and only one step at a time. Somehow like:
> Problem is that ECW layer through tileindex does not work.
> 1.) Does it work with one ECW? It did not, you fixed the build and
> gdalinfo is OK now but did you also test that MapServer is now OK with one
> ECW?
> 2.) If it is working with ECW then good. If it is not, make an
> additional test by converting one ECW into GeoTIFF and test your layer
> with it. If it is OK there is still something wrong with ECW support. If
> GeoTIFF does not work there is something else wrong and you must fix it
> before you can even know if the issue has to do with ECW at all.
> 3.) If one GeoTIFF and one ECW is OK then perhaps something is wrong
> with the tileindex. Make a new tileindex that contains a) only that one
> GeoTIFF you created in step 2 b) the same for the one original ECW. Do they
> work?
> Test with the file
> /home/mapas/dados/raster/ortos2012/006003Argb_12_d73.ecw. Does it exist? Is
> it empty? Can’t it be accessed due to wrong path or missing rights?
> (): Unable to access file. Corrupt, empty or missing file
> '/home/mapas/dados/raster/ortos2012/006003Argb_12_d73.ecw' for
> layer 'ortos2012'.
> As a general rule, add DEBUG 5 into your layer when debugging, and I
> suggest to add always PROJECTION blocks into MAP and LAYER level.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Marco Afonso
> *Lähetetty:* 10. huhtikuuta 2015 17:25
> *Vastaanottaja:* Jeff McKenna
> *Kopio:* mapserver
> *Aihe:* Re: [mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
> Hi again,
> Ok Jeff, I can change if I find something new.
> Not solved yet :p
> Ok, recompiled libecwj2 and gdal. gdalinfo is now reading the ecw
> correctly.
> But I still get the mapserver error... are there any further tests that I
> can do?
> Thanks.
> 2015-04-10 15:07 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> On 2015-04-10 10:34 AM, Marco Afonso wrote:
> Found this
> And reading moreover on http://trac.osgeo.org/gdal/wiki/ECW
> Those wiki pages are wonderful; please as you head down this path don't be
> afraid to update that ECW build wiki with any notes or changes you
> noticed. Thanks!
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
> Regards,
> Marco Afonso
> http://goo.gl/ZDtQjm
Regards,
Marco Afonso
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150411/0e5d353c/attachment.html>
