[mapserver-users] Fwd: Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
Marco Afonso
mafonso333 at gmail.com
Sat Apr 11 04:35:23 PDT 2015
Reboot and... voilá! It is working! :)
Cheers
2015-04-11 12:02 GMT+01:00 Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi>:
> So does it work with one tiff on Linux? If yes the file access theory is
> wrong.
> Jukka
> Lähettäjä: Marco Afonso <mafonso333 at gmail.com>
> Lähetetty: 11.4.2015 13:57
> Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
> Kopio: mapserver <mapserver-users at lists.osgeo.org>
> Aihe: Re: [mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
> Hi Jukka,
> We have exactly the same MS configuration, shapefile and ECW files
> working a older windows machine, so it seems to me that it is something to
> do with ms on linux.
> As I stated before, gdalinfo and ogrinfo are reading corretly the
> shapefile and ecw files throught command line.
> What file permitions would be required?
> Thanks
> 2015-04-11 11:21 GMT+01:00 Rahkonen Jukka (MML) <
>> Hi,
>> About how to test I have only one advice: Do it systematically.
>> Being systematically means building something pretty simple that works
>> first and add new stuff one and only one step at a time. Somehow like:
>> Problem is that ECW layer through tileindex does not work.
>> 1.) Does it work with one ECW? It did not, you fixed the build and
>> gdalinfo is OK now but did you also test that MapServer is now OK with one
>> ECW?
>> 2.) If it is working with ECW then good. If it is not, make an
>> additional test by converting one ECW into GeoTIFF and test your layer
>> with it. If it is OK there is still something wrong with ECW support. If
>> GeoTIFF does not work there is something else wrong and you must fix it
>> before you can even know if the issue has to do with ECW at all.
>> 3.) If one GeoTIFF and one ECW is OK then perhaps something is wrong
>> with the tileindex. Make a new tileindex that contains a) only that one
>> GeoTIFF you created in step 2 b) the same for the one original ECW. Do they
>> work?
>> Test with the file
>> /home/mapas/dados/raster/ortos2012/006003Argb_12_d73.ecw. Does it exist? Is
>> it empty? Can’t it be accessed due to wrong path or missing rights?
>> (): Unable to access file. Corrupt, empty or missing file
>> '/home/mapas/dados/raster/ortos2012/006003Argb_12_d73.ecw' for
>> layer 'ortos2012'.
>> As a general rule, add DEBUG 5 into your layer when debugging, and I
>> suggest to add always PROJECTION blocks into MAP and LAYER level.
>> -Jukka Rahkonen-
>> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
>> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Marco Afonso
>> *Lähetetty:* 10. huhtikuuta 2015 17:25
>> *Vastaanottaja:* Jeff McKenna
>> *Kopio:* mapserver
>> *Aihe:* Re: [mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
>> Hi again,
>> Ok Jeff, I can change if I find something new.
>> Not solved yet :p
>> Ok, recompiled libecwj2 and gdal. gdalinfo is now reading the ecw
>> correctly.
>> But I still get the mapserver error... are there any further tests that I
>> can do?
>> Thanks.
>> 2015-04-10 15:07 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
>> On 2015-04-10 10:34 AM, Marco Afonso wrote:
>> Found this
>> And reading moreover on http://trac.osgeo.org/gdal/wiki/ECW
>> Those wiki pages are wonderful; please as you head down this path don't
>> be afraid to update that ECW build wiki with any notes or changes you
>> noticed. Thanks!
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Regards,
>> Marco Afonso
>> http://goo.gl/ZDtQjm
> Regards,
> Marco Afonso
Regards,
Marco Afonso
Regards,
Marco Afonso
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150411/86495de2/attachment.html>
