[mapserver-users] mapcache config troubles, "Tile parameter not set"
thomas bonfort
thomas.bonfort at gmail.com
Wed Apr 29 02:21:12 PDT 2015
mapcache gets it's tile data from a <source> WMS service, not a tiled
one. Just remove the "mode=tile" part from your source->url, and make
sure your mapfile is configured to allow wms getmap requests (namely,
ows_srs and ows_enable_request metadatas are correctly set).
thomas
On 29 April 2015 at 11:18, Hal Mueller <hal at mobilegeographics.com> wrote:
> I don’t understand how to do that.
> It looks to me like I’m (erroneously) requesting a BBOX bounded tile instead of a gridded one. Does that jive with your read of my mistakes?
> H
>> On Apr 29, 2015, at 12:23 AM, Eichner, Andreas - SID <Andreas.Eichner at sid.sachsen.de> wrote:
>> I guess you're using an older version which doesn't check the "type" attribute and defaults to WMS. The "mode=tile" parameter is part of your URL and not build by MapCache. Everything else is an ordinary WMS request for a 5x5 metatile with 10px buffer: 5*256 + 2*10 = 1300.
>> So simly omit the mode parameter from the URL and let MapCache do it's WMS request. It will then itself respond using the requested tile service interface.
>> HTH
>> Von: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org]" im Auftrag von "Hal Mueller [hal at mobilegeographics.com]
>> Gesendet: Mittwoch, 29. April 2015 05:47
>> An: mapserver-users at lists.osgeo.org
>> Betreff: [mapserver-users] mapcache config troubles, "Tile parameter not set"
>> That request generates the following internal request, from Mapcache to Mapserver. It’s pretty close; the layers are right, but not the SERVICE, BBOX, WIDTH,
>> and HEIGHT parameters.
>> GET /cgi-bin/mapserv?mode=tile&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&STYLES=&BBOX=-20135347.738994,-7611905.024751,-7416226.232341,5107216.481902&WIDTH=1300&HEIGHT=1300&FORMAT=image/png&SRS=EPSG:3857&MAP=/data/web/www/mapserver/sites.map&LAYERS=property_pt%20property_poly
>> Mapcache.xml:
>> <source name="hpsites" type="tms">
>> <getmap>
>> <params>
>> <FORMAT>image/png</FORMAT>
>> <MAP>/data/web/www/mapserver/sites.map</MAP>
>> <LAYERS>property_pt%20property_poly</LAYERS>
>> </params>
>> </getmap>
>> <http>
>> <url>http://a.historypointer.com/cgi-bin/mapserv?mode=tile&</url>
>> </http>
>> </source>
