[mapserver-users] Legend difference in 5.6.1 and 6.4.1
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 30 04:29:30 PDT 2015
Could you check if the issue in 6.4 is related to the RESOLUTION parameter
in your mapfile (i.e. remove it and re-run)?
Mapserver 7.0 should be production ready unless you're using its remaining
blocking issue (TIME filters with MSSQL backends).
thomas
On 29 April 2015 at 22:34, mapserver <mapserver at markus-spring.de> wrote:
> Am 28.04.2015 um 08:11 schrieb thomas bonfort:
> Are you using the GD or AGG renderer? Do all truetype fonts exhibit
> this behavior? Can you test the 7.0 beta on this? Can you provide a
> self contained test-case to reproduce this?
> Lots of questions :)
> OK, to compare 5.6.7, 6.4.1 and 7.0.0beta, I compiled all three versions
> under centos 6.5 and
> created a simple mapfile:
> http://s.markus-spring.info/legend-agg.map
> Using the AGG renderer only because of its much better rendering, and got
> these results through the legend command:
> mapserver 5.6.7 (http://s.markus-spring.info/legend-agg-5.6.7.png)
> [image: legend-agg-5.6.7.png]
> mapserver 6.4.1 (http://s.markus-spring.info/legend-agg-6.4.1.png)
> [image: legend-agg-6.4.1.png]
> mapserver 7.0.0beta (http://s.markus-spring.info/legend-agg-7.0.0beta1.png
> [image: legend-agg-7.0.0beta1.png]
> There are clear differences in the rendered font sizes, but 5.6.7 and
> 7.0.0beta1 do not truncate the text, only 6.4.1 does.
> For me the question is if (or when) 7.0.0 is production quality already,
> and not only the mapserver itself but also mapcache, as the internet map
> services of the City of Munich are going to use that for the background
> maps.
> Best regards
> Markus
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150430/19222391/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150430/19222391/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150430/19222391/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150430/19222391/attachment-0005.png>
