[mapserver-users] html legend not working
Raffaele Morelli
raffaele.morelli at gmail.com
Mon Aug 3 05:16:27 PDT 2015
Short story: I can't get html legend to work...
legend.html file is in the same directory of the mapfile, as you can see the LABEL block is
a verbatim copy from Mapserver documentation.
The INCLUDE layer is a point layer with CLASS correctly defined.
This my request to test
http://localhost/cgi-bin/mapserv?MAP=/home/www/geomoose-2.8.0/maps/cen_default//cen_default.map&FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetLegendGraphic&_OLSALT=0.9622128666378558&SRS=EPSG:3857&SCALE=6933486.650500195&WIDTH=250&STYLE=&LAYER=sostegni
The legend is returned a png file, just like TEMPLATE statement wasn't taken into account.
Any hint?
Mapfile:
MAP
NAME 'XXX'
UNITS meters
EXTENT 728034.319166294 4193385.80350739 2183515.00526018 5960168.11180283
CONFIG 'MS_ERRORFILE' '/var/log/ms_error.log'
DEBUG 1
SIZE 800 600
SYMBOLSET "/home/www/geomoose-2.8.0/maps/symbols/symbols-catasto.sym"
FONTSET "/home/www/geomoose-2.8.0/maps/fonts/msfontset.txt"
RESOLUTION 72
PROJECTION
#"init=epsg:32632"
#"init=epsg:4326"
"init=epsg:3857"
#"init=epsg:900913"
END
OUTPUTFORMAT
NAME "png"
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "GAMMA=0.75"
END
OUTPUTFORMAT
NAME "gif"
DRIVER GD/GIF
MIMETYPE "image/gif"
IMAGEMODE PC256
EXTENSION "gif"
END
OUTPUTFORMAT
NAME "png8"
DRIVER AGG/PNG8
MIMETYPE "image/png; mode=8bit"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "QUANTIZE_FORCE=on"
FORMATOPTION "QUANTIZE_COLORS=256"
END
OUTPUTFORMAT
NAME "jpeg"
DRIVER AGG/JPEG
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
OUTPUTFORMAT
NAME "svg"
DRIVER CAIRO/SVG
MIMETYPE "image/svg+xml"
IMAGEMODE RGB
EXTENSION "svg"
END
OUTPUTFORMAT
NAME "pdf"
DRIVER CAIRO/PDF
MIMETYPE "application/x-pdf"
IMAGEMODE RGB
EXTENSION "pdf"
END
OUTPUTFORMAT
NAME "GTiff"
DRIVER GDAL/GTiff
MIMETYPE "image/tiff"
IMAGEMODE RGB
EXTENSION "tif"
END
OUTPUTFORMAT
NAME "kml"
DRIVER KML
MIMETYPE "application/vnd.google-earth.kml.xml"
IMAGEMODE RGB
EXTENSION "kml"
END
OUTPUTFORMAT
NAME "kmz"
DRIVER KMZ
MIMETYPE "application/vnd.google-earth.kmz"
IMAGEMODE RGB
EXTENSION "kmz"
END
OUTPUTFORMAT
NAME "cairopng"
DRIVER CAIRO/PNG
IMAGEMODE RGB
EXTENSION "png"
END
WEB
IMAGEPATH "/home/www/tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "CEN"
"wms_onlineresource" "http://localhost/cgi-bin/cen?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities"
"wms_enable_request" "*"
"wms_srs" "EPSG:32632 EPSG:4326 EPSG:900913 EPSG:3857"
END # Metadata
END # Web
LEGEND
STATUS ON
KEYSIZE 18 12
# LABEL object
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
TEMPLATE "legend.html" ### HTML template file
END
INCLUDE 'sostegni_italia.map'
END
«My mama said to get things done
You'd better not mess with Major Tom»
