[mapserver-users] rendering a raster crossing the antimeridian through a WMS
fred p
mapoubelle22 at gmail.com
Wed Aug 12 06:08:10 PDT 2015
Hello,
I do not manage do fully render in a Mapserver WMS a raster that crosses
the antimeridian when I request a -180°/+180° longitude bbox.
This is the request :
mapserv -nh
"QUERY_STRING=map=mapfile.map&layers=polar_orbiting_avhrr4&styles=&service=WMS&format=image%2Fpng&request=GetMap&height=400&width=800&version=1.1.1&bbox=-179.99%2C-89.99%2C179.99%2C89.99&exceptions=application%2Fvnd.ogc.se_inimage&srs=EPSG%3A4326&transparent=TRUE
In the result image, I only get the western side of the raster, near the
+180°. Nothing for the eastern part near the -180°.
How to solve this problem ?
This is a description of the raster :
Driver: GTiff/GeoTIFF
Files: /tmp/polar_orbiting_avhrr4.tiff
Size is 7021, 4321
Coordinate System is:
GEOGCS["unnamed ellipse",
DATUM["unknown",
SPHEROID["unnamed",6378160,298.2539162964669]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Origin = (135.000000000000000,0.000000000000000)
Pixel Size = (0.009257940464321,-0.009257116408239)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 135.0000000, 0.0000000) (135d 0' 0.00"E, 0d 0' 0.01"N)
Lower Left ( 135.0000000, -40.0000000) (135d 0' 0.00"E, 40d 0' 0.00"S)
Upper Right ( 200.000, 0.000) (200d 0' 0.00"E, 0d 0' 0.01"N)
Lower Right ( 200.000, -40.000) (200d 0' 0.00"E, 40d 0' 0.00"S)
Center ( 167.5000000, -20.0000000) (167d30' 0.00"E, 20d 0' 0.00"S)
Band 1 Block=7021x1 Type=Byte, ColorInterp=Gray
This is the mapfile contents :
MAP
STATUS ON
NAME "foo"
CONFIG "MS_ERRORFILE" "stderr"
IMAGETYPE "agg"
MAXSIZE 8192
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME "agg"
DRIVER "AGG/PNG"
MIMETYPE "image/png8"
IMAGEMODE "PC256"
EXTENSION "png"
END
WEB
METADATA
"ows_enable_request" "*"
"ows_sld_enabled" "true"
"wms_feature_info_mime_type" "text/html"
"wms_srs" "epsg:4326"
END
END
LAYER
STATUS ON
TYPE RASTER
NAME "polar_orbiting_avhrr4"
DATA "/tmp/polar_orbiting_avhrr4.tiff"
OFFSITE 0 0 0
PROCESSING "RESAMPLE=NEAREST"
END
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150812/bec2be91/attachment.html>
