[mapserver-users] rendering a raster crossing the antimeridian through a WMS
fred p
mapoubelle22 at gmail.com
Wed Aug 12 07:43:31 PDT 2015
Thanks to Jeff for the answer.
I simplified the mapfile to make it easier to read.
Below I give the mapfile with these additional elements. I do not have
warnings anymore with a GetCapabilities request but the image I get whith a
GetMap request is still incomplete.
Note that I get an error (*msProcessProjection(): Projection library error.
proj error "projection not named" for ""*) with a projection block in the
layer section if I declare the real projection definition (*"+proj=longlat
+a=6378160 +b=6356775 +no_defs "*). No error with *"+init=epsg:4326"* which
is closed to the real projection definition. As I have read somewhere that
if not present the projection is read in the data file, I have removed it
(the image I get is the same).
MAP
STATUS ON
NAME "foo"
CONFIG "MS_ERRORFILE" "stderr"
IMAGETYPE "agg"
MAXSIZE 8192
EXTENT -180 -90 180 90
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME "agg"
DRIVER "AGG/PNG"
MIMETYPE "image/png8"
IMAGEMODE "PC256"
EXTENSION "png"
END
WEB
METADATA
"ows_enable_request" "*"
"ows_sld_enabled" "true"
"wms_feature_info_mime_type" "text/html"
"ows_onlineresource" "http://127.0.0.1:8080/wms"
"wms_title" "WMS"
"wms_srs" "epsg:4326"
END
END
LAYER
STATUS ON
TYPE RASTER
NAME "polar_orbiting_avhrr4"
DATA "/tmp/polar_orbiting_avhrr4.tiff"
OFFSITE 0 0 0
PROCESSING "RESAMPLE=NEAREST"
METADATA
"wms_title" "foo"
END
#PROJECTION
# "init=epsg:4326"
#END
#PROJECTION
# "+proj=longlat +a=6378160 +b=6356775 +no_defs"
#END
END
END
2015-08-12 13:37 GMT+00:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> On 2015-08-12 10:08 AM, fred p wrote:
>> Hello,
>> I do not manage do fully render in a Mapserver WMS a raster that crosses
>> the antimeridian when I request a -180°/+180° longitude bbox.
>> This is the request :
>> mapserv -nh
>> "QUERY_STRING=map=mapfile.map&layers=polar_orbiting_avhrr4&styles=&service=WMS&format=image%2Fpng&request=GetMap&height=400&width=800&version=1.1.1&bbox=-179.99%2C-89.99%2C179.99%2C89.99&exceptions=application%2Fvnd.ogc.se_inimage&srs=EPSG%3A4326&transparent=TRUE
>> In the result image, I only get the western side of the raster, near the
>> +180°. Nothing for the eastern part near the -180°.
>> How to solve this problem ?
>> This is a description of the raster :
>> Driver: GTiff/GeoTIFF
>> Files: /tmp/polar_orbiting_avhrr4.tiff
>> Size is 7021, 4321
>> Coordinate System is:
>> GEOGCS["unnamed ellipse",
>> DATUM["unknown",
>> SPHEROID["unnamed",6378160,298.2539162964669]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433]]
>> Origin = (135.000000000000000,0.000000000000000)
>> Pixel Size = (0.009257940464321,-0.009257116408239)
>> Metadata:
>> AREA_OR_POINT=Area
>> Image Structure Metadata:
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left ( 135.0000000, 0.0000000) (135d 0' 0.00"E, 0d 0' 0.01"N)
>> Lower Left ( 135.0000000, -40.0000000) (135d 0' 0.00"E, 40d 0' 0.00"S)
>> Upper Right ( 200.000, 0.000) (200d 0' 0.00"E, 0d 0' 0.01"N)
>> Lower Right ( 200.000, -40.000) (200d 0' 0.00"E, 40d 0' 0.00"S)
>> Center ( 167.5000000, -20.0000000) (167d30' 0.00"E, 20d 0' 0.00"S)
>> Band 1 Block=7021x1 Type=Byte, ColorInterp=Gray
>> This is the mapfile contents :
>> MAP
>> STATUS ON
>> NAME "foo"
>> IMAGETYPE "agg"
>> MAXSIZE 8192
>> PROJECTION
>> "init=epsg:4326"
>> END
>> OUTPUTFORMAT
>> NAME "agg"
>> DRIVER "AGG/PNG"
>> IMAGEMODE "PC256"
>> EXTENSION "png"
>> END
>> WEB
>> METADATA
>> END
>> END
>> LAYER
>> STATUS ON
>> TYPE RASTER
>> OFFSITE 0 0 0
>> END
>> END
> By the looks of your layer, before tackling any problems, be sure to
> execute a GetCapabilities request to your service, and be sure to remove
> any "WARNING" messages returned. For example, I bet that you have warnings
> for missing metadata of wms_title, wms_srs, as well as missing PROJECTION
> block for your layer.
> It's good practice to first remove the warnings on any WMS service
> (because those warnings will cause problems for downstream users of your
> service).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150812/e3a8128c/attachment.html>
