[mapserver-users] Mapserver 7.0 and NODATA setting
Andrea Peri
aperi2007 at gmail.com
Tue Aug 18 00:28:53 PDT 2015
I have a clearly response from the log.
The nodata is unsupported for this kind of rasters.
> LoadGDALImage(rt_sat.LC8191.rt.attuale): NODATA value -9999 in GDAL
>file or PROCESSING directive largely ignored. Not yet fully supported for
>unclassified scaled data. The NODATA value is excluded from auto-scaling
>min/max computation, but will not be transparent.
So I must found another solution for my rasters.
Regards.
2015-08-18 9:08 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> So my question is a little different.
> Seem that mapserver was not able to automatically understand the
> NODATA values of floating point rasters.
> In my usecase: the NODATA value is -9999.0
> I produce the catalog using gdaltindex, and apply the result to mapserver 7.
> The result is this:
> http://tinyurl.com/ndsdyr8
> The only partially solution I found was to set
> OFFSITE 0 0 0
> but it is acceptable for my usecase because the black color is a color
> really available inside the rasters and it is not usable as a
> transparent color.
> Is this an issue for mapserver 7 ?
> Thx,
> A.
> 2015-08-17 16:11 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi Jukka.
>> Perhaps you have right !
>> The NODATA setting is an ancient setting that I reuse always in my
>> mapfiles but only now I notice that the mapserver document don't
>> report him.
>> So more probably it is a false setting.
>> But , if the nodata setting dont exist, how say to the mapserver to
>> filter the nodata of a floating raster ?
>> Thx.
>>> Andrea Peri
>>> qwerty àèìòù
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
