[mapserver-users] The new composite block in python swig api
Andrea Peri
aperi2007 at gmail.com
Tue Aug 18 23:56:09 PDT 2015
Hi Steve.
Thx for hint.
It dont seem work.
I
Querying the help from python I can see that the "compositer" object
is defined inside the layerObj, but dont seem to have any opacity var
inside it.
I try this:
The compositer object is defined, but seem don be any opacity variable
inside it.
I also check the code of swig inside the file "swiginc/layer.i"
I can see that there is still the setOpacity under layer and the
getOpacity instead
has a 100 value hardcoded.
void setOpacity(int opacity)
msSetLayerOpacity(self, opacity);
int getOpacity() {
if(self->compositer) return (self->compositer->opacity);
return (100);
Should I open an issue for this ?
2015-08-19 0:38 GMT+02:00 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
> There doesn't look to be specific support for it in the SWIG configuration. The SWIG interface for layers does reference it in the getOpacity/setOpacity methods but for backwards compatibility reasons. The structure is exposed to SWIG however and should be accessible even without special methods. In perl, something like this should work:
> $layer->{compositor}->{opacity} = 50;
> $layer->{compositor}->{comp_op} = $mapscript::MS_COMPOP_SCREEN;
> Does that help?
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
> Sent: Saturday, August 15, 2015 1:37 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] The new composite block in python swig api
> Hi,
> I dont find the new Composite block availability in the doc of python api swig.
> Is it instead available in python?
> Thx,
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
