[mapserver-users] split one geojson into tiles
TC Haddad
tchaddad at gmail.com
Wed Aug 19 15:31:47 PDT 2015
On Wed, Aug 19, 2015 at 3:16 PM, zach cruise <zachc1980 at gmail.com> wrote:
> On 8/19/15, TC Haddad <tchaddad at gmail.com> wrote:
> > Hi Zach
> > If you set up Mapserver to serve the original geojson layer as WFS
> > service[1] with geojson output [2], you can then pass in the bounding
> boxes
> > (using the WFS URL parameter BBOX=) of the tiles that you want to create.
> > You will get back the resulting geojson tiles as text in the browser and
> > can save them to wherever you want to serve them from.
> > [1] http://mapserver.org/ogc/wfs_server.html
> > [2]
> http://mapserver.org/output/template_output.html#outputformat-declarations
> i tried but you can't set zoom levels/precision with wfs [1] and geojson
> [2].
Yes - you must use BBOX= with WFS. You can get all the BBOX info you need
by using globalmaptiles.py for your area of interest. You can get that
script here:
http://www.maptiler.org/google-maps-coordinates-tile-bounds-projection/
> > OR, a much simpler process would be to use ogr2ogr and skip Mapserver
> > entirely.
> > see the clipping options mentioned here:
> > http://www.gdal.org/ogr2ogr.html
> interesting. i tried gdal2tiles but it creates raster not vector tiles.
Yes OGR2OGR is for vector to vector conversions. Spatial extent options can
be passed in using the BBOXes obtained from the same script mentioned above.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150819/978475d3/attachment.html>
