[mapserver-users] Multiple MapCache configuration files
geographika
geographika at gmail.com
Mon Aug 24 05:51:00 PDT 2015
As per the configuration guide I have a single xml configuration file
for all MapCache layers. This is set in httpd.conf (I'm using ms4w, and
running on a Windows server):
<IfModule mapcache_module>
<Directory "/ms4w/apps/mapcache/">
Order Allow,Deny
Allow from all
</Directory>
MapCacheAlias /mapcache "C:/ms4w/apps/mapcache/mapcache.xml"
</IfModule>
However I'm using MapCache on a development server and hosting several
different applications. I create the xml file dynamically for each
application, however with this approach I either have to change the
above path and restart Apache, or merge all the xml files together to a
single file.
Is there anyway to change which xml file is used using a querystring, or
is there any other suggested approach to handling multiple mapcache.xml
files?
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150824/06f3b224/attachment.html>
