[mapserver-users] [mapserver-dev] pink screen after activating several layers (mapserver version 6.2.0)
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Dec 3 06:35:21 PST 2015
Please reply to the list so everyone can benefit from the questions and
answers and there are a lot of other people that might have input to the
problem.
On 12/3/2015 5:35 AM, Donald wrote:
> Hi Steve,
> I don't believe that it is a problem with open layers. I tested
The point is to load the pink tile in a separate window so you can view
the error message and see why it failed.
> individually one layer at a time and I could conclude that I got the
> pink screen when a certain amount of activated layers are reached
> regardless of the order. Do you know if mapserver has some configuration
> that restrict the number of layers to render or some configuration about
> memory limit to render the layers ?
No, I do not think this is the case. How many layers are in your mapfile?
-Steve W
> thanks
> 2015-12-02 16:28 GMT+00:00 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>:
> On 12/2/2015 11:22 AM, Donald wrote:
> cheers,
> I have several layers that I can activate. When I activate all
> at once I get
> a pink screen. If I activate a layer individually by selecting
> one at a time
> I still get a pink screen even though some layers are correctly
> drawn. I
> checked the error log and I the last log line I have says
> "freeing map at
> 0xa022230". To see the map again I have to unselect all layers.
> Any thoughs on how to solve the problem ?
> Mostly likely it is only one of some of the layers that are having
> an issue. So trying, selecting one layer at a time to figure out
> which layer is causing the problem.
> Also a "pink screen" sounds like you are using OpenLayers and the
> pink is for a failure to render the image. In FireFox, right click
> on the pink image and select view image this image or copy the image
> url and paste it into a new tab/window and you might get an error
> message that would be helpful.
> -Steve W
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
