[mapserver-users] [Mac OS X] Impossible to load MapScript	module with PHP
    Ben Madin
    ben at ausvet.com.au
    Fri Dec 11 05:28:36 PST 2015
Did you look at kyngchaos.com
Even if you only use his unix frameworks, then compile your own php, you will be most of the way there.
otherwise, if you want to persist with home-brew, I’d put it onto their list
cheers
Ben
> On 2015-12-11, at 20:38 , Léonard DUMONT <dumont.leonard at gmail.com> wrote:
> Finally it was not so hard, but the problem is still the same... I have PHP 5.6.16 and Mapscript 6.4.1 both installed with Homebrew, and I still have the same error :
> Warning: PHP Startup: MapScript: Unable to initialize module
> Module compiled with module API=20100525
> PHP    compiled with module API=20131226
> These options need to match
>  in Unknown on line 0
> Any ideas ?
> Best regards,
> Léonard Dumont
> 2015-12-11 13:03 GMT+01:00 Léonard DUMONT <dumont.leonard at gmail.com <mailto:dumont.leonard at gmail.com>>:
> Ok, thanks for your answer. I thought there could have been another solution, but I'll try to install PHP with homebrew.
> Cordialement,
> Léonard Dumont
> 2015-12-11 10:33 GMT+01:00 Ben Madin <ben at ausvet.com.au <mailto:ben at ausvet.com.au>>:
> Um, you are correct, the extension has not been compiled to work with the same version of php as you are trying to use.
> I can only suggest that you get your php from the same source as your mapscript... (I guess homebrew, but my success there has been limited and conflicted) or compile php yourself, them mapserver with the php-mapscript option set.
> You may be up for some pain...! You could also try kyngchaos.com <http://kyngchaos.com/>, but I'm not sure if he is still providing a php suitable for what you want.
> On 10 December 2015 at 17:28, Leonard <dumont.leonard at gmail.com <mailto:dumont.leonard at gmail.com>> wrote:
> Hi everyone !
> I am a new user trying to use mapserver, and I have some problems... One of
> them is that I cannot load the php_mapscript extension. I have PHP 5.6.11
> installed with  php-osx.liip.ch <http://php-osx.liip.ch/> <http://php-osx.liip.ch <http://php-osx.liip.ch/>>   and mapscript 6.4
> installed with Homebrew, and there seems to be a conflict, since when I run
> php I get this warning :
> I added this line to my php.ini file :
> extension="/usr/local/opt/mapserver-64/mapscript/php/php_mapscript.so"
> Thanks for your help !
> Léonard Dumont.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mac-OS-X-Impossible-to-load-MapScript-module-with-PHP-tp5240669.html <http://osgeo-org.1560.x6.nabble.com/Mac-OS-X-Impossible-to-load-MapScript-module-with-PHP-tp5240669.html>
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapserver-users <http://lists.osgeo.org/mailman/listinfo/mapserver-users>
> Ben Madin
> BVMS PhD, MANZCVS
> t : +61 8 6102 5535 <tel:%2B61%208%206102%205535>
> m : +61 448 887 220 <tel:%2B61%20448%20887%20220>
> e : ben at ausvet.com.au <mailto:ben at ausvet.com.au>
> AusVet Animal Health Services
> Western Australia
> www.ausvet.com.au <http://www.ausvet.com.au/>
Ben Madin
t : +61 8 6102 5535
m : +61 448 887 220
18/27 Market Street, Fremantle
Western Australia
AusVet's website:  http://www.ausvet.com.au        Find our office: http://w3w.co/leader.code.frozen
This transmission is for the intended addressee only and is confidential information. If you have received this transmission in error, please delete it and notify the sender. The contents of this email are the opinion of the writer only and are not endorsed by AusVet Animal Health Services unless expressly stated otherwise. Although AusVet uses virus scanning software we do not accept liability for viruses or similar in any attachments. Thanks for reading. The average disclaimer at the bottom of an email is probably never read but contributes substantially to increasing the size of packet being sent through the internet and ultimately congestion.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151211/5022fe66/attachment.htm>
More information about the MapServer-users
