[mapserver-users] [Mac OS X] Impossible to load MapScript module with PHP
Léonard DUMONT
dumont.leonard at gmail.com
Fri Dec 11 07:15:11 PST 2015
Hi and thanks for your answer !
I am using Mac OS X 10.9.5 (Mavericks), but I have no idea of how I could
do this API stuff...
Cheers,
Léonard.
2015-12-11 16:09 GMT+01:00 William Kyngesburye <woklist at kyngchaos.com>:
> Yeah, I haven't done anything with Mapserver or PHP in a long time. If
> and when I do, my plan is/will be to skip a custom PHP and build mapscript
> for the system PHP. Though that could get messy because different OS X
> versions have different PHP API versions.
> What OS X version do you have? On my Yosemite Mac, the system PHP API
> version is 20121212, so maybe you have El Capitan? It's possible that the
> system php (your API=20131226) is running in Apache, it's a bit tricky to
> get Apache to use a custom PHP, and especially on El Capitan with it's SIP
> security it might be harder. You might have to do the whole AMP stack
> custom.
> > On Dec 11, 2015, at 8:15 AM, Léonard DUMONT <dumont.leonard at gmail.com>
> wrote:
> > Thanks for your advices. The PHP binaries from kyngchaos.com are a
> little bit old, I'll try to see on the Homebrew list.
> > Cheers,
> > Léonard.
> > 2015-12-11 14:28 GMT+01:00 Ben Madin <ben at ausvet.com.au>:
> > Did you look at kyngchaos.com
> > Even if you only use his unix frameworks, then compile your own php, you
> will be most of the way there.
> > otherwise, if you want to persist with home-brew, I’d put it onto their
> list
> > cheers
> > Ben
> >> On 2015-12-11, at 20:38 , Léonard DUMONT <dumont.leonard at gmail.com>
> wrote:
> >> Finally it was not so hard, but the problem is still the same... I have
> PHP 5.6.16 and Mapscript 6.4.1 both installed with Homebrew, and I still
> have the same error :
> >> Warning: PHP Startup: MapScript: Unable to initialize module
> >> Module compiled with module API=20100525
> >> PHP compiled with module API=20131226
> >> These options need to match
> >> in Unknown on line 0
> >> Any ideas ?
> >> Best regards,
> >> Léonard Dumont
> >> 2015-12-11 13:03 GMT+01:00 Léonard DUMONT <dumont.leonard at gmail.com>:
> >> Ok, thanks for your answer. I thought there could have been another
> solution, but I'll try to install PHP with homebrew.
> >> Cordialement,
> >> Léonard Dumont
> >> 2015-12-11 10:33 GMT+01:00 Ben Madin <ben at ausvet.com.au>:
> >> Um, you are correct, the extension has not been compiled to work with
> the same version of php as you are trying to use.
> >> I can only suggest that you get your php from the same source as your
> mapscript... (I guess homebrew, but my success there has been limited and
> conflicted) or compile php yourself, them mapserver with the php-mapscript
> option set.
> >> You may be up for some pain...! You could also try kyngchaos.com, but
> I'm not sure if he is still providing a php suitable for what you want.
> >> On 10 December 2015 at 17:28, Leonard <dumont.leonard at gmail.com> wrote:
> >> Hi everyone !
> >> I am a new user trying to use mapserver, and I have some problems...
> One of
> >> them is that I cannot load the php_mapscript extension. I have PHP
> 5.6.11
> >> installed with php-osx.liip.ch <http://php-osx.liip.ch> and
> mapscript 6.4
> >> installed with Homebrew, and there seems to be a conflict, since when I
> run
> >> php I get this warning :
> >> I added this line to my php.ini file :
> >> extension="/usr/local/opt/mapserver-64/mapscript/php/php_mapscript.so"
> >> Thanks for your help !
> >> Léonard Dumont.
> >> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Mac-OS-X-Impossible-to-load-MapScript-module-with-PHP-tp5240669.html
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> Ben Madin
> >> BVMS PhD, MANZCVS
> >> t : +61 8 6102 5535
> >> m : +61 448 887 220
> >> e : ben at ausvet.com.au
> >> AusVet Animal Health Services
> >> Western Australia
> >> www.ausvet.com.au
> > Ben Madin
> > t : +61 8 6102 5535
> > m : +61 448 887 220
> > 18/27 Market Street, Fremantle
> > Western Australia
> > AusVet's website: http://www.ausvet.com.au Find our office:
> http://w3w.co/leader.code.frozen
> > This transmission is for the intended addressee only and is confidential
> information. If you have received this transmission in error, please delete
> it and notify the sender. The contents of this email are the opinion of the
> writer only and are not endorsed by AusVet Animal Health Services unless
> expressly stated otherwise. Although AusVet uses virus scanning software we
> do not accept liability for viruses or similar in any attachments. Thanks
> for reading. The average disclaimer at the bottom of an email is probably
> never read but contributes substantially to increasing the size of packet
> being sent through the internet and ultimately congestion.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151211/6c16c047/attachment-0001.html>
