[mapserver-users] Color the world, but not my country
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Dec 11 13:00:49 PST 2015
How about Inline polygon covering -180 -90 180 90 in epsg:4326 http://www.mapserver.org/input/vector/inline.html?
-Jukka Rahkonen-
Wim Vanbelle wrote:
I came across this, but I'm not quite sure to what other layer it should relate? I would only have the 'Netherlands' description of the borders.
I do not want to use the world dataset file, because it's too big. I cannot just add a 'complement' to the country layer or am I misinterpreting the mask function?
It would be solved I believe if I could add a LAYER which did not require a datasource and renders everything black, but that is not possible I believe, because mapserver always requires a type and the annotation type is deprecated since 6.2
Thanks in advance.
On 11 December 2015 at 20:57, Daniel Morissette <dmorissette at mapgears.com<mailto:dmorissette at mapgears.com>> wrote:
I think the MASK layer should do what you want:
http://mapserver.org/development/rfc/ms-rfc-79.html
Daniel
On 2015-12-11 2:37 PM, Wim Vanbelle wrote:
Dear,
I have a country shapefile and I would like to style everything, besides
the one feature in the polygon.
This is a shapefile layer, so I'm wondering on how I could possibly
improve this:
LAYER
NAME "gadm"
TYPE POLYGON
TRANSPARENCY 70
DATA "gadm28.shp"
STATUS default
DEBUG 4
CLASS
EXPRESSION ("[ISO]" != "NLD")
style
color "#000000"
end
END
END
Basically, I would like to only use the data from the netherlands (NLD),
because it's a lot less data, and color everything else, besides the one
feature that it has.
My above (working example) is taking the entire world and only filtering
out what I want to see.
The goal is to visually create a map of a single country and block out
all the rest ;-). It's rendered as a tile layer. (gmaps)
Thanks in advance for your feedback.
Best regards,
Wim
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Daniel Morissette
http://www.mapgears.com/
T: +1 418-696-5056 #201
http://evouala.com/ - Location Intelligence Made Easy
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151211/9ce67c42/attachment.html>
