[mapserver-users] contour layers with tileindex issues
Kralidis, Tom (EC/EC)
tom.kralidis at canada.ca
Mon Dec 14 07:23:22 PST 2015
Hi all: using 6.4.1 we are attempting to display (via WMS) GRIB2 data as a contour layer backed by a tileindex setup. Invoking a basic WMS 1.3.0 GetMap request returns the following ServiceExceptionReport:
msDrawMap(): Image handling error. Failed to draw layer named 'RDPS.ETA_PN'.
msContourLayerOpen(): Image handling error. Unable to open GDAL dataset.
msBuildPath: Unable to access file.
msContourLayerSetTimeFilter(): General error message. Assertion failed: Contour layer not opened!!!
When I point directly to a single GRIB2 file (via the DATA directive), all works as expected.
Layer definition snippet below.
Any idea what I'm doing wrong here? Or whether this is a suitable workaround? Note we are bound to UbuntuGIS stable.
Thanks
..Tom
LAYER
NAME "RDPS.ETA_PN"
STATUS ON
DEBUG OFF
TILEINDEX "/data/tileindex/foo.shp" # doesn't work
# DATA "/data/foo.grib2" # works
TYPE LINE
CONNECTIONTYPE CONTOUR
PROCESSING "BAND=1"
PROCESSING "CONTOUR_INTERVAL=400"
PROCESSING "CONTOUR_ITEM=pixel"
DUMP TRUE
TEMPLATE "ttt.html"
PROJECTION
"proj=stere"
"lat_0=90"
"lat_ts=60"
"lon_0=249"
"k=90"
"x_0=0"
"y_0=0"
"a=6371229"
"b=6371229"
"units=m"
"no_defs"
END
END
