[mapserver-users] contour layers with tileindex issues
Kralidis, Tom (EC/EC)
tom.kralidis at canada.ca
Tue Dec 15 05:54:09 PST 2015
Hi Jukka: thanks for the info. The files exist on disk. I've opened a GitHub issue w/ a simple test case at https://github.com/mapserver/mapserver/issues/5212
..Tom
> -----Original Message-----
> From: Rahkonen Jukka (MML) [mailto:jukka.rahkonen at maanmittauslaitos.fi]
> Sent: 2015-12-14 11:01
> To: Kralidis, Tom (EC/EC); mapserver-users at lists.osgeo.org
> Subject: Re: contour layers with tileindex issues
> Hi,
> I would try to use TILEINDEX through OGR but that gets tricky because one
> LAYER probable can't have two CONNECTIONTYPEs. Perhaps it would work by
> using a tileindex layer as a tileindex for contours.
> LAYER #OGR tileindex layer
> NAME "ogr_tileindex"
> CONNECTIONTYPE OGR
> CONNECTION ....
> LAYER #countour layer
> TILEINDEX "ogr_tileindex"
> CONNECTIONTYPE CONTOUR PROCESSING "BAND=1"
> But based on the error message Mapserver tries already open your GRIB2 files
> through GDAL/OGR. Are you sure that you have valid path in the "location" field
> of the tileindex shape?
> -Jukka Rahkonen-
> Kralidis, Tom wrote:
> Hi all: using 6.4.1 we are attempting to display (via WMS) GRIB2 data as a
> contour layer backed by a tileindex setup. Invoking a basic WMS 1.3.0 GetMap
> request returns the following ServiceExceptionReport:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'RDPS.ETA_PN'.
> msContourLayerOpen(): Image handling error. Unable to open GDAL dataset.
> msBuildPath: Unable to access file.
> msContourLayerSetTimeFilter(): General error message. Assertion failed:
> Contour layer not opened!!!
> When I point directly to a single GRIB2 file (via the DATA directive), all works as
> expected.
> Layer definition snippet below.
> Any idea what I'm doing wrong here? Or whether this is a suitable workaround?
> Note we are bound to UbuntuGIS stable.
> Thanks
> ..Tom
> LAYER
> NAME "RDPS.ETA_PN"
> STATUS ON
> DEBUG OFF
> TILEINDEX "/data/tileindex/foo.shp" # doesn't work # DATA "/data/foo.grib2"
> # works TYPE LINE CONNECTIONTYPE CONTOUR PROCESSING "BAND=1"
> PROCESSING "CONTOUR_INTERVAL=400"
> PROCESSING "CONTOUR_ITEM=pixel"
> DUMP TRUE
> TEMPLATE "ttt.html"
> PROJECTION
> "proj=stere"
> "lat_0=90"
> "lat_ts=60"
> "lon_0=249"
> "k=90"
> "x_0=0"
> "y_0=0"
> "a=6371229"
> "b=6371229"
> "units=m"
> "no_defs"
> END
> END
