[mapserver-users] cmake issue
kelly elton
its.the.doc at gmail.com
Tue Dec 15 10:58:14 PST 2015
Yeah so after tinkering with it, if I added my sdk bin directory
(C:\mapserver\SDK\release-1800\bin in this case) to my PATH environmental
variable, then it worked. Seems a little weird considering every other
plugin could properly read the CMAKE_PREFIX_PATH just fine.
On Tue, Dec 15, 2015 at 12:40 PM kelly elton <its.the.doc at gmail.com> wrote:
> Having issues running cmake on mapserver on windows using the sdk from
> gisinternals
> c:\mapserver\mapserver\build>cmake .. -DWITH_POSTGIS=0 -DWITH_CSHARP=1
> -DCMAKE_CURRENT_BINARY_DIR="C:\mapserver\swigwin-1.3.40" -DMSVC_VER=1800
> -DMSVC_VERSION=1600
> -DCMAKE_PREFIX_PATH="C:\mapserver\SDK\release-1800\bin;C:\mapserver\SDK\release-1800\include;C:\mapserver\SDK\release-1800\lib;c:\mapserver\regex-0.12;C:\mapserver\swigwin-1.3.40"
> CMake Error at CMakeLists.txt:69 (message):
> ICONV library/component/dependency could not be found.
> HINTS:
> - disable ICONV support by adding -DWITH_ICONV=0
> - add the ICONV install directory to the CMAKE_PREFIX_PATH variable
> (-DCMAKE_PREFIX_PATH="/path/to/ICONV-install-dir;/path/to/other/dirs"
> Call Stack (most recent call first):
> CMakeLists.txt:429 (report_optional_not_found)
> iconv.dll iconv.h and iconv.lib are all present in the sdk
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151215/e12d9fae/attachment.html>
