[mapserver-users] OGR GeoJSON stream output not working with FCGI
Even Rouault
even.rouault at spatialys.com
Tue Feb 10 03:41:35 PST 2015
Le mardi 10 février 2015 12:32:41, Tuikku Anttila a écrit :
> Hi,
> I am trying to get GeoJSON to work as a WFS output format, using an OGR
> outputformat with FORMATOPTION "storage=stream". With CGI, it works fine,
> but with FastCGI the response appears in the apache error log and I get an
> empty response in the browser. It works if I have FORMATOPTION
> "STORAGE=filesystem" instead of "stream" set in the OUTPUTFORMAT block.
> I am running Mapserver 6.4.1, have tried GDAL 1.10.1 and 1.11.1. I have
> tried this on Ubuntu Server 14.04 and CentOS 6.6, and with both Apache
> mod_fcgid and Nginx spawn-fcgi. Everything seems to work, but the output
> does not show in the browser, just in the server logs. What could I be
> missing?
Tuikku,
This is issue https://github.com/mapserver/mapserver/pull/4858
It has been workarounded in MapServer 6.4.2 by switching to storage=memory
instead with FCGI, and properly fixed in master (if used with GDAL trunk
2.0dev)
Regards,
Even
> Regards,
> Tuikku Anttila
http://www.spatialys.com
More information about the MapServer-users
