[mapserver-users] copyright, logos, etc
Julien Cigar
jcigar at ulb.ac.be
Wed Feb 11 06:59:12 PST 2015
On Wed, Feb 11, 2015 at 01:32:54PM +0000, Eichner, Andreas - SID wrote:
> > what I really need to do is to
> > make an SQL query (something like select name from map where id=%MYID%)
> > and use that attribute in the TEXT part of the FEATURE section (something
> > like FEATURE POINTS x y END TEXT "Species name: [name]" END)
> > Any idea is welcome on how to do that in the "Mapserver way" ..
> I have not test it but I would suggest replacing the inlined feature with a OGR point layer connected to a MYSQL view or a OGR VRT datasource that associates every line with the position of the annotation.
> 1) MYSQL view:
> CREATE OR REPLACE VIEW species_annotation AS SELECT id, GeomFromText('POINT(60 -10)') AS Shape, name FROM map;
> LAYER
> # FEATURE
> # POINTS
> # 60 -10 # the offset (from lower left) in pixels
> # END # Points
> # TEXT "© xyz company 2006" # this is your displaying text
> # END # Feature
> CONNECTIONTYPE ogr
> CONNECTION 'MYSQL: ...'
> DATA 'species_annotation'
> LABELITEM 'name'
> FILTER ([id]=%MYID%)
> END # Layer
> 2) OGR VRT datasource:
> In species_annotation.vrt:
> <OGRVRTDataSource>
> <OGRVRTLayer name="species_annotation">
> <SrcDataSource>MYSQL: ...</SrcDataSource>
> <SrcSQL>SELECT id, 60 as x, -10 as y, name FROM map</SrcSQL>
> <FID>id</FID>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>NULL</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="x" y="y" reportSrcColumn="false" />
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Test with: ogrinfo -al species_annotation.vrt -fid <existing id>
> LAYER
> CONNECTIONTYPE ogr
> CONNECTION 'species_annotation.vrt'
> LABELITEM 'name'
> FILTER ([id] = %MYID%)
> END # Layer
> HTH
It's a little ugly but it works with:
https://gist.github.com/silenius/f0b0fb856b82a7c70eaa
Thank you very much!
Julien Cigar
Belgian Biodiversity Platform (http://www.biodiversity.be)
PGP fingerprint: EEF9 F697 4B68 D275 7B11 6A25 B2BB 3710 A204 23C0
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150211/52999c7f/attachment-0001.pgp>
