[mapserver-users] the lines one above other
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Thu Feb 12 04:52:57 PST 2015
I'm not sure about this but AFAIK MapServer draws features in the order they are returned by the query. For Shapefiles there is the sortshp utility. If you're on a relational database like PostGIS or OracleSpatial you can try including the "ORDER BY prio" within the DATA. But since MS wraps it into a subquery the database might still return the features out of order.
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> bounces at lists.osgeo.org] Im Auftrag von Vladimir
> Gesendet: Donnerstag, 12. Februar 2015 12:02
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] the lines one above other
> Hello All!
> The task is to show multilevel junction of highway.
> The lines should be at the same layer and has the same style, for example
> see orange lines on attached pic:
> [img]http://s14.postimg.org/yk40e0nq9/crossroad.jpg[/img]
> Is it possible to draw the lines one above other by an one layer?
> May be some method of Z-index for features in a layer exists?
> Thanks for any guidance to display this kind of crossroads.
> Vladimir
