[mapserver-users] the lines one above other
Lars Fricke
fricke at gisberater.com
Thu Feb 12 05:24:28 PST 2015
For me it works by sorting in the map file. I then put the needed layers
into my WMS request. The order does not matter in the request it seems.
Best
Lars
Am 12.02.2015 um 13:52 schrieb Eichner, Andreas - SID:
> I'm not sure about this but AFAIK MapServer draws features in the order they are returned by the query. For Shapefiles there is the sortshp utility. If you're on a relational database like PostGIS or OracleSpatial you can try including the "ORDER BY prio" within the DATA. But since MS wraps it into a subquery the database might still return the features out of order.
>> -----Ursprüngliche Nachricht-----
>> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
>> bounces at lists.osgeo.org] Im Auftrag von Vladimir
>> Gesendet: Donnerstag, 12. Februar 2015 12:02
>> An: mapserver-users at lists.osgeo.org
>> Betreff: [mapserver-users] the lines one above other
>> Hello All!
>> The task is to show multilevel junction of highway.
>> The lines should be at the same layer and has the same style, for example
>> see orange lines on attached pic:
>> [img]http://s14.postimg.org/yk40e0nq9/crossroad.jpg[/img]
>> Is it possible to draw the lines one above other by an one layer?
>> May be some method of Z-index for features in a layer exists?
>> Thanks for any guidance to display this kind of crossroads.
>> Vladimir
