[mapserver-users] MapServer 6.4.1 OGR output error
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Mon Feb 23 02:48:04 PST 2015
To me it seems the WFS code uses msReturnTemplateQuery() from maptemplate.c but this is not exported to (PHP-)MapScript... I would guess that the only way to get OGR output would be to fake a OWS-Request:
<?php
$map = ms_newMapObj("./toto.map");
$req = new OWSRequestObj();
$args = Array("service" => "WFS", "request" => "GetFeature", "version" => "1.1.0", "typename" => "Bati");
foreach($args as $param => $value) $req->setParameter($param, $value);
$req->setParameter("outputformat", $_REQUEST["type_fichier"]);
// $map->loadOWSParameters($req);
$map->owsDispatch($req);
Requires enabling the request type and the output format:
WEB
METADATA
Ows_enable_request "*"
Wfs_getfeature_formatlist "dxf midmif shapezip csv kmz"
END
END
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> bounces at lists.osgeo.org] Im Auftrag von Bruno D
> Gesendet: Freitag, 20. Februar 2015 16:27
> An: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] MapServer 6.4.1 OGR output error
> Hi Andreas,
> Thanks for your answer. I tried using savequeryasgml(), but it creates a
> blank gml file that only contains the following text :
> /<?xml version="1.0" encoding="ISO-8859-1"?>
> <msGMLOutput
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> </msGMLOutput>/
> I'll look into that, but as you stated there is almost no documentation...
> Could someone who succeeded in outputting a DXF/SHP/... file through OGR
> post a working example ?
> Thanks !
> Bruno
> View this message in context: http://osgeo-
> org.1560.x6.nabble.com/MapServer-6-4-1-OGR-output-error-
> tp5172655p5188948.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
