[mapserver-users] WFS filter creates a query using a number instead of text
bteluk at gmail.com
bteluk at gmail.com
Thu Feb 26 21:28:32 PST 2015
I can't shine any light on the problem but I have encountered the same
problem. Using MapServer v6.0.3, with Postgres 9.1.3, PostGIS v 1.5.3, GDAL
v1.8.0.WFS Posted Query looks like this:The DescribeFeatureType for that
layer shows the following for the attribute:PostgreSQL has the attribute
field specified as a string:Server responds:Postgres Log shows:Certainly
appears that the query put to PostGIS is incorrect - it's not quoting the
literal value.I have a similar MapServer layer that's based on ESRI
Shapefile - same effective attribute set up, and it works fine - of course
it's not going via PostgreSQL/PostGIS - so it seems that the problem is
specific to the PostgreSQL/PostGIS interface?I tried mucking around with
including PostgreSQL casts on the literal eg. "3168::text", using
"CAST(pcode as int)" on the PropertyName etc with no luck. Using
"PropertyIsLike" did work, but is not an ideal solution.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-filter-creates-a-query-using-a-number-instead-of-text-tp5130361p5190393.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150226/81f8a5c2/attachment.html>
