[mapserver-users] compiling error core.c in mapcache with cygwin
Gery
gamejihou at hotmail.com
Wed Jan 7 05:59:04 PST 2015
Andy Colson wrote
> You need the Apache Portable Runtime library. Its a generic lib, not the
> webserver.This gives an overview of all the area's it
> covers:http://apr.apache.org/docs/apr/1.4/modules.html
Thanks Andy for the reply, I do have apr, no idea if it's the generic lib or
webserver one but they are 1.4 version:Gery at gery
/opt/mapcache/mapcache-rel-1-2-1/build$ cygcheck -c | grep aprapr1
1.4.8-1 OKaprutil1
1.5.4-1 OKlibapr1
1.4.8-1 OKlibapr1-debuginfo
1.4.8-1 OKlibapr1-devel
1.4.8-1 OKlibaprutil1
1.5.4-1 OKlibaprutil1-debuginfo
1.5.4-1 OKlibaprutil1-devel
1.5.4-1 OKBased on Stephen's answer
(http://stackoverflow.com/questions/27755442/compiling-error-core-c-in-mapcache-with-cygwin),
I should compile mapcache only as cgi (ie., no apache module), so I
used:cmake .. -DCMAKE_LEGACY_CYGWIN_WIN32=0 -DWITH_SQLITE=0
-DWITH_MAPSERVER=1
-DMAPSERVER_LIBRARY="/opt/mapserver/mapserver-6.4.1/build/libmapserver.dll.a"
-DCMAKE_PREFIX_PATH="/opt/mapserver/mapserver-6.4.1;" -DWITH_APACHE=0but I
get the same error pointing to core.c. I used mapserver flags to use cgi as
explained by Pablo's post
(http://lists.osgeo.org/pipermail/mapserver-users/2013-September/075296.html).So,
after cmake I get:Gery at gery /opt/mapcache/mapcache-rel-1-2-1/build$ cmake ..
-DCMAKE_LEGACY_CYGWIN_WIN32=0 -DWITH_SQLITE=0 -DWITH_MAPSERVER=1
-DCMAKE_PREFIX_PATH="/opt/mapserver/mapserver-6.4.1;" -DWITH_APACHE=0-- The
C compiler identification is GNU 4.8.3-- The CXX compiler identification is
GNU 4.8.3-- Check for working C compiler: /usr/bin/gcc.exe-- Check for
working C compiler: /usr/bin/gcc.exe -- works-- Detecting C compiler ABI
info-- Detecting C compiler ABI info - done-- Check for working CXX
compiler: /usr/bin/c++.exe-- Check for working CXX compiler:
/usr/bin/c++.exe -- works-- Detecting CXX compiler ABI info-- Detecting CXX
compiler ABI info - done-- Looking for strncasecmp-- Looking for strncasecmp
- found-- Looking for symlink-- Looking for symlink - found-- Found ZLIB:
/usr/lib/libz.dll.a (found version "1.2.8")-- Found PNG:
/usr/lib/libpng.dll.a (found version "1.5.18")-- Found JPEG:
/usr/lib/libjpeg.dll.a-- Found CURL: /usr/lib/libcurl.dll.a (found version
"7.38.0")-- Found APR: /usr/lib/libapr-1.dll.a-- Found APU:
/usr/lib/libaprutil-1.dll.a-- Found PkgConfig: /usr/bin/pkg-config.exe
(found version "0.28")-- checking for module 'pixman'-- package 'pixman'
not found-- checking for module 'pixman-1'-- found pixman-1, version
0.32.4-- Found PIXMAN: /usr/lib/libpixman-1.dll.a-- Found MAPSERVER:
/opt/mapserver/mapserver-6.4.1/build/libmapserver.dll.a-- * Configured
options for the mapcache library-- * Mandatory components-- * png:
/usr/lib/libpng.dll.a-- * jpeg: /usr/lib/libjpeg.dll.a-- * Curl:
/usr/lib/libcurl.dll.a-- * Apr: /usr/lib/libapr-1.dll.a-- * Optional
components-- * PIXMAN: /usr/lib/libpixman-1.dll.a-- * SQLITE: disabled--
* Berkeley DB: disabled-- * Memcache: disabled-- * TIFF: disabled-- *
GeoTIFF: disabled-- * Experimental TIFF write support: disabled-- *
PCRE: disabled-- * Experimental mapserver support:
/opt/mapserver/mapserver-6.4.1/build/libmapserver.dll.a-- Found GDAL:
/usr/local/lib/libgdal.dll.a-- Found GEOS: /usr/local/lib/libgeos_c.dll.a--
* Seeder Configuration Options:-- * GEOS: /usr/local/lib/libgeos_c.dll.a--
* OGR: /usr/local/lib/libgdal.dll.a-- Found FCGI: /usr/lib/libfcgi.dll.a-- *
CGI Configuration Options:-- * FastCGI: /usr/lib/libfcgi.dll.a-- * Apache
Module support status: DISABLED-- Configuring done-- Generating done-- Build
files have been written to: /opt/mapcache/mapcache-rel-1-2-1/buildand after
make I get:Gery at gery /opt/mapcache/mapcache-rel-1-2-1/build$ makeScanning
dependencies of target mapcache[ 2%] Building C object
CMakeFiles/mapcache.dir/lib/axisorder.c.o[ 5%] Building C object
CMakeFiles/mapcache.dir/lib/buffer.c.o[ 7%] Building C object
CMakeFiles/mapcache.dir/lib/cache_bdb.c.o[ 10%] Building C object
CMakeFiles/mapcache.dir/lib/cache_disk.c.o[ 12%] Building C object
CMakeFiles/mapcache.dir/lib/cache_memcache.c.o[ 15%] Building C object
CMakeFiles/mapcache.dir/lib/cache_sqlite.c.o[ 17%] Building C object
CMakeFiles/mapcache.dir/lib/cache_tiff.c.o[ 20%] Building C object
CMakeFiles/mapcache.dir/lib/cache_tokyocabinet.c.o[ 22%] Building C object
CMakeFiles/mapcache.dir/lib/configuration.c.o[ 25%] Building C object
CMakeFiles/mapcache.dir/lib/configuration_xml.c.o[ 27%] Building C object
CMakeFiles/mapcache.dir/lib/core.c.o/opt/mapcache/mapcache-rel-1-2-1/lib/core.c:
In function
‘mapcache_prefetch_tiles’:/opt/mapcache/mapcache-rel-1-2-1/lib/core.c:81:3:
error: unknown type name ‘apr_thread_t’ apr_thread_t **threads;
^/opt/mapcache/mapcache-rel-1-2-1/lib/core.c:82:3: error: unknown type name
‘apr_threadattr_t’ apr_threadattr_t *thread_attrs;
^/opt/mapcache/mapcache-rel-1-2-1/lib/core.c:83:7: warning: unused variable
‘nthreads’ [-Wunused-variable] int nthreads;
^/opt/mapcache/mapcache-rel-1-2-1/lib/core.c:82:21: warning: unused variable
‘thread_attrs’ [-Wunused-variable] apr_threadattr_t *thread_attrs;
^/opt/mapcache/mapcache-rel-1-2-1/lib/core.c:81:18: warning: unused variable
‘threads’ [-Wunused-variable] apr_thread_t **threads;
^CMakeFiles/mapcache.dir/build.make:287: recipe for target
'CMakeFiles/mapcache.dir/lib/core.c.o' failedmake[2]: ***
[CMakeFiles/mapcache.dir/lib/core.c.o] Error 1CMakeFiles/Makefile2:63:
recipe for target 'CMakeFiles/mapcache.dir/all' failedmake[1]: ***
[CMakeFiles/mapcache.dir/all] Error 2Makefile:116: recipe for target 'all'
failedmake: *** [all] Error 2How could I know if my apr packages are causing
the problem? is there a way to test that without installing a newer apache
version?Gery
View this message in context: http://osgeo-org.1560.x6.nabble.com/compiling-error-core-c-in-mapcache-with-cygwin-tp5179881p5180356.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150107/ede3e0d5/attachment.html>
