[mapserver-users] KML output with blank point
Dietmar Stolz
dietmar.stolz at freenet.de
Thu Jan 8 02:40:10 PST 2015
Dear list,
I still have a problem with kml output.
My kml output basically works.
Everything works fine with line and polygon type, I get correct kml files.
Point layers works also but mapserver generated blank png's.
The bitmap exist in the right directory with the right size.
The url path in the kml file is right.
I can see the kml point layer in the gis, the points have tooltips and
are clickable.
The bitmaps have 24 bpp.
Pixmap or vector layer symbols makes no difference.
Debug 5 shows no error and no kml specific information.
MapServer version 6.4.1 on windows 7 64 bit
OUTPUTFORMAT
NAME "kml"
DRIVER "KML"
MIMETYPE "application/vnd.google-earth.kml+xml"
IMAGEMODE RGB
EXTENSION "kml"
FORMATOPTION "STORAGE=memory"
FORMATOPTION "FORM=simple"
END
LAYER
# DEBUG 5
NAME "point"
TYPE POINT
DATA "kml_test.shp"
METADATA
"ows_title" "test"
"ows_abstract" "test"
"KML_DESCRIPTION" "test"
"KML_NAME_ITEM" "TEXT"
# "wfs_getfeature_formatlist" "text/csv,gml,geojson,xml,kml"
# "KML_OUTPUTASRASTER" "true"
END
CLASS
STYLE
SYMBOL "point"
SIZE 36
COLOR 255 0 0
OUTLINECOLOR 0 255 0
END
END
END
SYMBOL
NAME "point"
TYPE ELLIPSE
POINTS
10 10
END
FILLED TRUE
END
KML-Output:
|<?xml version="1.0" encoding="UTF-8"?>
||<kml xmlns="http://www.opengis.net/kml/2.2">
|| <Document>
|| <Style id="LayerFolder_check">
|| <ListStyle>
|| <listItemType>check</listItemType>
|| </ListStyle>
|| </Style>
|| <Style id="LayerFolder_checkHideChildren">
|| <ListStyle>
|| <listItemType>checkHideChildren</listItemType>
|| </ListStyle>
|| </Style>
|| <Style id="LayerFolder_checkOffOnly">
|| <ListStyle>
|| <listItemType>checkOffOnly</listItemType>
|| </ListStyle>
|| </Style>
|| <Style id="LayerFolder_radioFolder">
|| <ListStyle>
|| <listItemType>radioFolder</listItemType>
|| </ListStyle>
|| </Style>
|| <name>OsthessenNetz</name>
|| <Style id="style_symbol_point_3.6_ff0000ff">
|| <IconStyle>
|| <Icon>
|| <href>http://localhost/gistemp/54ae5c24_4474_0.png</href>
|| </Icon>
|| </IconStyle>
|| </Style>
|| <Folder>
|| <name>point</name>
|| <visibility>1</visibility>
|| <styleUrl>#LayerFolder_check</styleUrl>
|| <Placemark>
|| <name>point.0</name>
|| <styleUrl>#style_symbol_point_3.6_ff0000ff</styleUrl>
|| <description>test</description>
|| <Point>
|| <coordinates>
|| 9.73281948,50.58202641
|| </coordinates>
|| </Point>
|| </Placemark>
|| </Folder>
|| </Document>
||</kml>|
Any ideas?
Thank you
Dietmar
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150108/e2e446ab/attachment.html>
