[mapserver-users] [EXTERNAL] KML output with blank point
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Thu Jan 8 05:34:26 PST 2015
Please always reply back to the list so others can benefit.
If all your images are empty, then there is something up with your symbol rendering. Do you get valid symbols if you generate an map image without kml output?
I've had no problem with vector and bitmap point symbols in KML output. But the images rendered to the tmp directory render correctly so that is where your problem lies.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
From: Dietmar Stolz <dietmar.stolz at freenet.de<mailto:dietmar.stolz at freenet.de>>
Date: Thursday, January 8, 2015 at 8:22 AM
To: Michael Smith <michael.smith at erdc.dren.mil<mailto:michael.smith at erdc.dren.mil>>
Subject: Re: [EXTERNAL] [mapserver-users] KML output with blank point
Thanks Mike,
IMAGEURL is ok, the paths is already an absolute:
<Style id="style_symbol_point_3.6_ff0000ff">
<IconStyle>
<Icon>
<href>http://localhost/gistemp/54ae5c24_4474_0.png</href>
</Icon>
</IconStyle>
</Style>
I can fetch the icon via browser.
The icon is rendered but the image itself is blank.
Dietmar
Am 08.01.2015 um 13:09 schrieb Smith, Michael ERDC-RDE-CRREL-NH:
Dietmar,
Make sure your IMAGEURL is set to a Fully Qualified URL. Otherwise mapserver will not set the full URL to your point images.
Mike
Michael Smith
US Army Corps
Date: Thursday, January 8, 2015 at 5:40 AM
To: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [EXTERNAL] [mapserver-users] KML output with blank point
Resent-From: Michael Smith <michael.smith at usace.army.mil<mailto:michael.smith at usace.army.mil>>
Dear list,
I still have a problem with kml output.
My kml output basically works.
Everything works fine with line and polygon type, I get correct kml files.
Point layers works also but mapserver generated blank png's.
The bitmap exist in the right directory with the right size.
The url path in the kml file is right.
I can see the kml point layer in the gis, the points have tooltips and are clickable.
The bitmaps have 24 bpp.
Pixmap or vector layer symbols makes no difference.
Debug 5 shows no error and no kml specific information.
MapServer version 6.4.1 on windows 7 64 bit
OUTPUTFORMAT
NAME "kml"
DRIVER "KML"
MIMETYPE "application/vnd.google-earth.kml+xml"
IMAGEMODE RGB
EXTENSION "kml"
FORMATOPTION "STORAGE=memory"
FORMATOPTION "FORM=simple"
END
LAYER
# DEBUG 5
NAME "point"
TYPE POINT
DATA "kml_test.shp"
METADATA
"ows_title" "test"
"ows_abstract" "test"
"KML_DESCRIPTION" "test"
"KML_NAME_ITEM" "TEXT"
# "wfs_getfeature_formatlist" "text/csv,gml,geojson,xml,kml"
# "KML_OUTPUTASRASTER" "true"
END
CLASS
STYLE
SYMBOL "point"
SIZE 36
COLOR 255 0 0
OUTLINECOLOR 0 255 0
END
END
END
SYMBOL
NAME "point"
TYPE ELLIPSE
POINTS
10 10
END
FILLED TRUE
END
KML-Output:
<kml xmlns="http://www.opengis.net/kml/2.2"<http://www.opengis.net/kml/2.2>>
<Document>
<Style id="LayerFolder_check">
<ListStyle>
<listItemType>check</listItemType>
</ListStyle>
</Style>
<Style id="LayerFolder_checkHideChildren">
<ListStyle>
<listItemType>checkHideChildren</listItemType>
</ListStyle>
</Style>
<Style id="LayerFolder_checkOffOnly">
<ListStyle>
<listItemType>checkOffOnly</listItemType>
</ListStyle>
</Style>
<Style id="LayerFolder_radioFolder">
<ListStyle>
<listItemType>radioFolder</listItemType>
</ListStyle>
</Style>
<name>OsthessenNetz</name>
<IconStyle>
<Icon>
</Icon>
</IconStyle>
</Style>
<Folder>
<name>point</name>
<visibility>1</visibility>
<styleUrl>#LayerFolder_check</styleUrl>
<Placemark>
<name>point.0</name>
<styleUrl>#style_symbol_point_3.6_ff0000ff</styleUrl>
<description>test</description>
<Point>
<coordinates>
9.73281948,50.58202641
</coordinates>
</Point>
</Placemark>
</Folder>
</Document>
</kml>
Any ideas?
Thank you
Dietmar
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150108/ef4bbb48/attachment-0001.html>
