[mapserver-users] Setting up a JSONP service
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Tue Jan 13 07:52:21 PST 2015
That's what I get on the console:
$ MS_MAPFILE=$(pwd)/IHK_Handelsflaechen.map ./mapserv QUERY_STRING='service=WFS&version=1.1.0&request=GetFeature&featureid=IHK.71247&outputformat=geojson&callback=foobar'Content-Disposition: attachment; filename=result.dat
Content-Type: application/json; subtype=geojson; charset=utf-8
foobar({
"type": "FeatureCollection",
"features": [
{ "type": "Feature", "properties": { "PLZ": "09648", ..., "LANDKREIS": "Mittelsachsen" }, "geometry": { "type": "Point", "coordinates": [ 4568447.14, 5650577.57 ] } }
In other words, the JSON is enclosed by "foobar(" and ");": The relevant parts of the mapfile are:
OUTPUTFORMAT
NAME 'geojson'
# NAME 'jsonp'
DRIVER 'OGR/GEOJSON'
MIMETYPE 'application/json; subtype=geojson; charset=utf-8'
# MIMETYPE 'text/javascript; charset=utf-8'
FORMATOPTION 'STORAGE=stream'
FORMATOPTION 'FORM=simple'
FORMATOPTION 'LCO:COORDINATE_PRECISION=5'
FORMATOPTION 'JSONP=%callback%'
END
WEB
VALIDATION
callback '.*'
# default_callback 'jsonp'
END
END
The default value does not work, so the substitution parameter must be given.
> -----Ursprüngliche Nachricht-----
> Von: Lars Fricke [mailto:fricke at gisberater.com]
> Gesendet: Dienstag, 13. Januar 2015 16:39
> An: Eichner, Andreas - SID; mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Setting up a JSONP service
> Hi Andreas,
> I guess I'm still doing something wrong. If I use
> http://localhost:8082/wfs?SERVICE=WFS&VERSION=1.1.0&request=GetFeature&TYP
> ENAME=HU&outputformat=geojson&SRS=EPSG:3857&bbox=793732,6570204,793765,657
> 0228&callback=foobar
> I'm getting the exact same output as before. What are you getting? Can
> you post an example of your servers response?
> Thank you so much.
> Best
> Lars
> Am 13.01.2015 um 15:57 schrieb Eichner, Andreas - SID:
> > Arg.. outputformat=geojson also works, only had a typo...
> >> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> >> bounces at lists.osgeo.org] Im Auftrag von Eichner, Andreas - SID
> >> Gesendet: Dienstag, 13. Januar 2015 15:18
> >> An: 'lars.fricke at skendata.de'; mapserver-users at lists.osgeo.org
> >> You need to append the "callback" parameter to the query string:
> >> You can test on the command line, too:
> >> MS_MAPFILE=/path/to/mapfile ./mapserv
> >> QUERY_STRING='service=WFS&version=1.1.0&request=GetFeature&typename=HU&
> SRS=EPSG:3857&bbox=793732,6570204,793765,6570228&outputformat=application/
> >> json; subtype=geojson; charset=utf-8&callback=foobar'
> >> Please note that IMHO "geojson" alone isn't enough. The full mimetype
> >> string should be used as reported by GetCapabilities.
> >> HTH
> >>> Gesendet: Dienstag, 13. Januar 2015 14:22
> >>> Hi,
> >>> I compiled MapServer after applying the patch (at least I think it was
> >>> applied). Unfortunately the output is not JSONP format. Maybe I'm
> >>> getting something wrong. So here is what I did:
> >>> Applied
> >>> patch -p1 < jsonp.diff
> >>> I got an updated mapogroutput.c.
> >>> I then compiled with the following options:
> >>> cmake -DCMAKE_INSTALL_PREFIX=/opt \
> >>> -DCMAKE_PREFIX_PATH="/usr/local;/opt" \
> >>> -DWITH_CLIENT_WFS=ON \
> >>> -DWITH_CLIENT_WMS=ON \
> >>> -DWITH_CURL=ON \
> >>> -DWITH_SOS=ON \
> >>> -DWITH_PHP=0 \
> >>> -DWITH_PYTHON=ON \
> >>> -DWITH_SVGCAIRO=OFF \
> >>> -DWITH_ORACLESPATIAL=0 \
> >>> -DWITH_MSSQL2008=OFF \
> >>> -DWITH_THREAD_SAFETY=ON \
> >>> -DWITH_LIBXML2=ON \
> >>> -DWITH_MYSQL=ON\
> >>> -DWITH_SDE=0 .. >../configure.out.txt
> >>> Which goes through without any warning.
> >>> I do make next, getting a few warnings about the Python bindings but
> >>> nothing about mapogroutput (ecept that it was compiled). Then sudo
> make
> >>> install. No warnings.
> >>> I then set a symlink to the new mapserv file inside cgi-bin and start
> my
> >>> apache.
> >>> I changed my mapfile as you indicated:
> >>> WEB
> >>> FOOTER "test"
> >>> IMAGEPATH "/var/www/html/tmp/"
> >>> TEMPPATH "/var/www/html/tmp/"
> >>> IMAGEURL "/html/tmp/"
> >>> METADATA
> >>> "wfs_title" "Test"
> >>> "ows_onlineresource" "http://localhost:8082/wfs?"
> >>> "ows_enable_request" "*"
> >>> "ows_srs" "EPSG:3857"
> >>> "wfs_srs" "EPSG:3857"
> >>> "wfs_getfeature_formatlist" "geojson,csv,ogrgml"
> >>> "wfs_encoding" "UTF-8"
> >>> END # METADATA
> >>> VALIDATION
> >>> callback ".*"
> >>> END
> >>> END # WEB
> >>> OUTPUTFORMAT
> >>> NAME "geojson"
> >>> DRIVER "OGR/GEOJSON"
> >>> MIMETYPE "application/json; subtype=geojson; charset=utf-8"
> >>> FORMATOPTION "STORAGE=stream"
> >>> FORMATOPTION "FORM=SIMPLE"
> >>> FORMATOPTION "LCO:COORDINATE_PRECISION=5"
> >>> FORMATOPTION "JSONP=%callback%"
> >>> END
> >>> Unfortunately calling:
> >>> 0228
> >>> gives me a result as before without your changes:
> >>> "crs": { "type": "name", "properties": { "name":
> >>> "urn:ogc:def:crs:EPSG::3857" } },
> >>> "features": [
> >>> { "type": "Feature", "properties": { "gml_id": "", "UMRING_ID":
> >>> "36245586"}, "geometry": { "type": "Polygon", "coordinates": [ [ [
> >>> 793757.73417, 6570202.31642 ], [ 793762.85989, 6570195.63821 ], [
> >>> 793770.20682, 6570201.30901 ], [ 793765.08276, 6570207.98411 ], [
> >>> 793757.73417, 6570202.31642 ] ] ] } },
> >>> "36245583"}, "geometry": { "type": "Polygon", "coordinates": [ [ [
> >>> 793752.31968, 6570224.89917 ], [ 793747.96097, 6570230.48534 ], [
> >>> 793732.07033, 6570218.01607 ], [ 793740.12777, 6570207.69188 ], [
> >>> 793742.99908, 6570209.94649 ], [ 793747.5696, 6570204.08902 ], [
> >>> 793761.16105, 6570214.75134 ], [ 793752.94726, 6570225.27397 ], [
> >>> 793752.31968, 6570224.89917 ] ] ] } },
> >>> "36245550"}, "geometry": { "type": "Polygon", "coordinates": [ [ [
> >>> 793735.55884, 6570231.00753 ], [ 793738.78194, 6570226.81082 ], [
> >>> 793746.26949, 6570232.5959 ], [ 793743.04798, 6570236.79266 ], [
> >>> 793735.55884, 6570231.00753 ] ] ] } }
> >>> I also tried this with an AJAX call from Javascript, giving me the
> >>> exactly same result.
> >>> I get an error message trying to use the result in Leaflet telling me
> a
> >>> ";" is missing. I assume it should look like this:
> >>> var testlayer = [{
> >>> "features": [
> >>> I'm not sure what is going on. Am I not applying the changes correctly
> >>> or is my call wrong?
> >>> Thanks for you great support.
> >>> Best
> >>> Lars
> >>> Am 09.01.2015 um 15:30 schrieb Eichner, Andreas - SID:
> >>>> Hi,
> >>>> I've attached a quick'n dirty solution (against master). When applied
> >> to
> >>>> mapogroutput.c you can set a JSONP formatoption to the callback name:
> >>>> OUTPUTFORMAT
> >>>> NAME 'geojson'
> >>>> END
> >>>> This needs of course a WEB.VALIDATION:
> >>>> WEB
> >>>> VALIDATION
> >>>> callback '.*'
> >>>> END
> >>>> END
> >>>> Would be great if you can test if this works (looks good to me). The
> >>> Devs might have a look if this could be integrated into master until
> OGR
> >>> has an appropriate layer creation option (solution described by Even).
> >>>> Greetings
> users-
> >>>>> bounces at lists.osgeo.org] Im Auftrag von Lars Fricke
> >>>>> Gesendet: Freitag, 9. Januar 2015 11:24
> >>>>> An: mapserver-users at lists.osgeo.org
> >>>>> Hello,
> >>>>> first of all: Thank you for your support!
> >>>>> Sorry for the late reply but I unfortunately was ill.
> >>>>> @ Steve:
> >>>>> I read about templating but also read that it is slower?
> >>>>> I do not have a lot of experience in writing templates. Would you
> >> mind
> >>>>> sharing a JSONP template?
> >>>>> @ Even: Thank you for your thoughts. Who would implement that change
> >>>>> though? I'm afraid I can't.
> >>>>> @ Jeff: I followed those links but I only found threads referring to
> >>>>> GeoServer or that were not related to my question. The GDAL page I
> >> did
> >>>>> study and that's how I managed to set up the GeoJSON service but
> >> thats
> >>>>> not the same unfortunately as it conflicts with the same origin
> >> policy.
> >>>>> Best
> >>>>> Lars
> >>>>> Am 30.12.2014 um 16:24 schrieb Lime, Steve D (MNIT):
> >>>>>> You can also use MapServer templates to accomplish this. It's a
> >> little
> >>>>> more work since you have to write the template but it's quite
> >> flexible
> >>>>> then. Usually I write the template to produce JSON and then use a
> >>> simple
> >>>>> wrapper template to produce JSONP. For example, jsonp.js looks like
> >>>>> (callback is passed in):
> >>>>>> // MapServer Template
> >>>>>> [callback](
> >>>>>> [include src="templates/json.js"]
> >>>>>> Output formats look like:
> >>>>>> OUTPUTFORMAT
> >>>>>> NAME 'JSON'
> >>>>>> DRIVER 'TEMPLATE'
> >>>>>> MIMETYPE 'application/json;'
> >>>>>> FORMATOPTION 'FILE=templates/json.js'
> >>>>>> FORMATOPTION 'ATTACHMENT=service.json'
> >>>>>> END
> >>>>>> OUTPUTFORMAT
> >>>>>> NAME 'JSONP'
> >>>>>> DRIVER 'TEMPLATE'
> >>>>>> FORMATOPTION 'FILE=templates/jsonp.js'
> >>>>>> END
> >>>>>> Steve
> >>>>>> -----Original Message-----
> >>>>>> From:mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-
> >> users-
> >>>>> bounces at lists.osgeo.org] On Behalf Of Lars Fricke
> >>>>>> Sent: Monday, December 29, 2014 5:34 AM
> >>>>>> To:mapserver-users at lists.osgeo.org
> >>>>>> Subject: [mapserver-users] Setting up a JSONP service
> >>>>>> Dear List,
> >>>>>> I have a WFS service running under MapServer that I would like to
> >>>>> operate as JSONP service. I managed to set GEOJSON as output format
> >> but
> >>> I
> >>>>> get "Cross-Origin-Request Blocked" if I try to call it with a
> >>> Javascript
> >>>>> client (using Leaflet L.layerJSON.
> >>>>>> The question is: Is it possible to set up a JSONP service from
> >>> Mapserver
> >>>>> and if yes, how? My current mapfile looks like this (relevant
> parts):
> >>>>>> # in WEB - METADATA
> >>>>>> OUTPUTFORMAT
> >>>>>> NAME "geojson"
> >>>>>> END
> >>>>>> If this would already be a correct JSONP service, I have to look on
> >>> the
> >>>>> Leaflet side for the error...
> >>>>>> Thanks for your help.
> >>>>>> Cheers
> >>>>>> Lars
> >>>>>> _______________________________________________
> >>>>>> mapserver-users mailing list
> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
