[mapserver-users] FW: Errors about mapcache configure in apache httpd
刘小二
liuxiaoer at live.cn
Tue Jan 13 17:12:38 PST 2015
Hi, list:
I had succeeded in compiling and installing the mapcache according to the guide, but there was something wrong with integrating mod_mapcache.so to apache httpd. The following is my logs about compiling and installing and httpd conf file.
mapcache.conf
<IfModule !mapcache_module>
LoadModule mapcache_module modules/mod_apreq2.so
</IfModule>
#<Directory /var/www/mapcache>
# Require all granted
#</Directory>
#MapCacheAlias /mapcache "/var/www/mapcache/mapcache.xml"
[root at localhost build]# systemctl status httpd.service -l
httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; disabled)
Active: failed (Result: exit-code) since 三 2015-01-14 08:19:05 CST; 7s ago
Process: 29697 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=0/SUCCESS)
Process: 29695 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 29695 (code=exited, status=1/FAILURE)
Status: "Total requests: 0; Current requests/sec: 0; Current traffic: 0 B/sec"
1月 14 08:19:05 localhost.localdomain httpd[29695]: httpd: Syntax error on line 56 of /etc/httpd/conf/httpd.conf: Syntax error on line 6 of /etc/httpd/conf.modules.d/10-mp-.conf: Cannot load modules/mod_mapcache.so into server: libmapcache.so.1: cannot open shared object file: No such file or directory
1月 14 08:19:05 localhost.localdomain systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
1月 14 08:19:05 localhost.localdomain systemd[1]: Failed to start The Apache HTTP Server.
1月 14 08:19:05 localhost.localdomain systemd[1]: Unit httpd.service entered failed state.
Any advice will be appreciated.
Regards,liuxiaoer
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150114/ed11d7bc/attachment.html>
