[mapserver-users] postgres layer not visible
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Jan 15 07:02:34 PST 2015
This is another reported issue with a pmapper demo, kassandraxx had similar troubles yesterday. Is there some workshop going on, I do not remember any mails about pmapper since many years.
Kassandraxx sent the following report which seems to mean that MapServer is using a deprecated function name "GeomFromText" while recent PostGIS supports only "ST_GeomFromText".
msDrawMap(): Image handling error. Failed to draw layer named 'Ager Firmanus'. <br>
msPostGISLayerWhichShapes(): Query error. Error (ERROR: function
geomfromtext(u nknown, integer) does not exist
LINE 1: ...geom,"gid" from "ager_firmanus" where the_geom && GeomFromTe...
HINT: No function matches the given name and argument types. You might need
to add explicit type casts.
) executing query: select
encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex
') as geom,"gid" from "ager_firmanus" where the_geom &&
GeomFromText('POLYGON((2 52691.191155437
4727437.25648659,252691.191155437 4871219.56915799,425287.594538
208 4871219.56915799,425287.594538208 4727437.25648659,252691.191155437
4727437. 25648659))',32633) <br>
We should know these things at least:
- Which MapServer version is used?
- Where is that pmapper demo?
- Who made and maintains it?
- When it has last time proved to work?
We would also need badly new good Mapserver tutorials and samples and I apologize that I have not been helping with making such even I have had some plans for that.
-Jukka Rahkonen-
Jeff McKenna wrote:
Hi Pasquale,
I always test my mapfile with the shp2img commandline utility (http://mapserver.org/utilities/shp2img.html). An example command would be:
shp2img -m pmapper_demo.map -o ttt.png -map_debug 3
That utility is often a massive help to diagnosing problems with layers. :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
On 2015-01-15 9:58 AM, Maiorano Pasquale wrote:
> Dear Sirs,
> I followed a Youtube tutorial trying to show a couple of shape file
> previously save on postgres DB. I modified the pmapper_demo.map and the
> related config_xxx.xml. When a run the following page
> /http://localhost/pmapper/map_default.phtml?config=gabon/ nothing
> happens. I created the following folder
> /C:\ms4w\apps\pmapper\pmapper-4.3.2\config\gabon/ where I stored the
> /pmapper_demo.map/. In the dir config I stored the file
> /config_gabon.xml/. You can find hereinafter the file pmapper_demo.map:
> # Adapt settings in map file <tt>pmapper_demo.map</tt> for the following
> tags to match settings
> # on your machine (see additionally MapServer documentation for detailed
> information):
> # MAP
> # SHAPEPATH
> # FONTSET
> # SYMBOLSET
> # WEB
> # IMAGEPATH
> # IMAGEURL
> # Start of map file
> MAP
> EXTENT 83684.2557031431 48040.09765625 455660.392391208 642189.8125
> UNITS meters
> #EXTENT -15 30 40 70
> #UNITS dd
> SIZE 600 500
> SHAPEPATH "../../../pmapper_demodata"
> SYMBOLSET "../common/symbols/symbols-pmapper.sym"
> FONTSET "../common/fonts/msfontset.txt"
> RESOLUTION 96
> IMAGETYPE png
> INTERLACE OFF
> #CONFIG "PROJ_LIB" "C:/proj/nad/"
> PROJECTION
> "proj=tmerc"
> "lat_0=0"
> "lon_0=12"
> "k=0.9996"
> "x_0=500000"
> "y_0=500000"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END # PROJECTION
> # Start of web interface definition
> WEB
> TEMPLATE "map.html"
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> #"MAPFILE_ENCODING" "ISO-8859-1"
> #"ows_title" "WMS Demo Server"
> #"ows_onlineresource" "http://wms.yourserver.org?owskey=test&"
> #"ows_srs" "EPSG:3035 EPSG:4326"
> END # Metadata
> END # Web
> # Start of Reference map definition
> REFERENCE
> IMAGE "../../images/gabon.png"
> SIZE 199 149
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END # Reference
> # Start of legend object
> LEGEND
> STATUS OFF
> IMAGECOLOR 255 255 255
> # OUTLINECOLOR 0 0 0
> POSITION ll
> KEYSIZE 18 12
> KEYSPACING 10 5
> TEMPLATE "void"
> LABEL
> TYPE TRUETYPE
> FONT "FreeSans"
> SIZE small
> POSITION AUTO
> COLOR 0 0 89
> OUTLINECOLOR 255 255 255
> ANTIALIAS TRUE
> END
> END
> # Start of ScaleBar definition
> SCALEBAR
> STATUS off
> TRANSPARENT off
> INTERVALS 4
> SIZE 200 3
> UNITS kilometers
> COLOR 250 250 250
> OUTLINECOLOR 0 0 0
> BACKGROUNDCOLOR 100 100 100
> STYLE 0
> POSTLABELCACHE true
> LABEL
> COLOR 0 0 90
> #OUTLINECOLOR 200 200 200
> SIZE small
> END # Label
> END # Reference
> # SYMBOLS USED IN PMAPPER
> # - 'circle' always necessary (used e.g. for highlight)
> # - 'square' used in currecnt map file
> # Symbols can also be defined via tag SYMBOLSET (see above)
> Symbol
> Name 'circle'
> Type ELLIPSE
> Filled TRUE
> Points
> 1 1
> END
> END
> Symbol
> Name 'square'
> Type VECTOR
> Filled TRUE
> Points
> 0 1
> 0 0
> 1 0
> 1 1
> 0 1
> END
> END
> #================== START OF LAYER SECTION =====================#
> LAYER
> CONNECTION "dbname='gabon' host=localhost port=5432 user='postgres'
> password='nicoletta' sslmode=disable"
> CONNECTIONTYPE POSTGIS
> DATA 'the_geom FROM "gabon_coastline_riproiettato" USING UNIQUE GID
> USING SRID=5223'
> EXTENT 131038.078125 48040.09765625 433953.28125 642189.8125
> METADATA
> "ows_title" "gabon_coastline_riproiettato"
> END # METADATA
> NAME "gabon_coastline_riproiettato"
> PROJECTION
> "proj=tmerc"
> "lat_0=0"
> "lon_0=12"
> "k=0.9996"
> "x_0=500000"
> "y_0=500000"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END # PROJECTION
> STATUS ON
> TILEITEM "location"
> TYPE LINE
> UNITS METERS
> CLASS
> STYLE
> COLOR 121 8 226
> WIDTH 1
> END # STYLE
> END # CLASS
> END # LAYER
> LAYER
> DATA 'the_geom FROM "public"."Fiumi_riproiettato" USING UNIQUE gid
> USING UNIQUE 5223'
> EXTENT 150981.730577697 166673.281916046 346296.768620565 389978.665308564
> METADATA
> "ows_title" "Fiumi_riproiettato"
> END # METADATA
> NAME "Fiumi_riproiettato"
> PROJECTION
> "proj=tmerc"
> "lat_0=0"
> "lon_0=12"
> "k=0.9996"
> "x_0=500000"
> "y_0=500000"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END # PROJECTION
> STATUS ON
> TILEITEM "location"
> TYPE LINE
> UNITS METERS
> CLASS
> STYLE
> COLOR 62 186 93
> WIDTH 1
> END # STYLE
> END # CLASS
> END # LAYER
> LAYER
> DATA 'the_geom FROM "public"."Confini_Gabon_SR_GabonTM" USING
> UNIQUE gid USING UNIQUE 5223'
> EXTENT 128874.546875 56689.61328125 781735.125 760206.0625
> METADATA
> "ows_title" "Confini_Gabon_SR_GabonTM"
> END # METADATA
> NAME "Confini_Gabon_SR_GabonTM"
> PROJECTION
> "proj=tmerc"
> "lat_0=0"
> "lon_0=12"
> "k=0.9996"
> "x_0=500000"
> "y_0=500000"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END # PROJECTION
> STATUS OFF
> TILEITEM "location"
> TYPE POLYGON
> UNITS METERS
> CLASS
> STYLE
> COLOR 133 45 126
> OUTLINECOLOR 0 0 0
> WIDTH 1
> END # STYLE
> END # CLASS
> END # LAYER
> END #Map
> Have you got any ideas where I am wrong?
> Any advice will be appreciated.
> Pasquale Maiorano
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
