[mapserver-users] postgres layer not visible
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Jan 19 04:58:50 PST 2015
You wrote earlier:
"When I run the shp2img utility it replies that the ID column does not exist, but using the pgadmin, I see the column named ID and is also the primary key of the table "Fiumi_riproiettato"!!!"
I wonder how you can see column "ID" is the table is created as to have a column ans primary key in "gid serial NOT NULL".
Do you really look at the same table with pgadmin?
-Jukka Rahkonen-
Maiorano Pasquale wrote:
Dear Brent Fraser and everybody,
The "Create Table" statement from Postgres is the following:
CREATE TABLE "Fiumi_riproiettato"
gid serial NOT NULL,
"Nome" character varying(80),
"Luinghezza" integer,
the_geom geometry(LineString),
CONSTRAINT "Fiumi_riproiettato_pkey" PRIMARY KEY (gid)
WITH (
OIDS=FALSE
ALTER TABLE "Fiumi_riproiettato"
OWNER TO postgres;
I'm looking forward to hearing You,
Pasquale
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150119/ac49f79d/attachment.html>
